Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 02-27-2007, 07:49 PM   #1
polo6979's Avatar
The absolute easiest way to make a windows boot screen.....
Sorry if this has been posted before...I think this is the easiest way to create a custom boot screen.
1. - Create a boot screen 640 x 480
Here is an example of one I created. (made for widescreen)
2. Down this free trial program called "Tuneup Utilities" from here..
Download Here
(You can remove program when you are done... screen will stay)
3. Open Tuneup Utilities - Click on "TuneUp Styler 2"
4. Click on "Change the windows XP boot screen, and create or download new boot screens"
5. Click on "New Screen"
6. Click on "Search Local Drives" and browse to the image you created.
After adding the photo click on "Save Boot Screen"
7. You will need to give it a name... Click OK
8. Highlight the screen you want to apply and click on "Install Boot Screen"
YOU ARE DONE....
After you reboot you will notice you now have two boot options. You can remove that by editing the boot.ini file on the root C drive. Just edit it in notepad and remove the line with "(TuneUp Backup)" in it. Here is a screen shot.
Hope this helps someone.
BMW 325ci Sport in the works
95% done
Front End - CENTRAFUSE ALL THE WAY!!
Here is my project.
polo6979 is offline   Reply With Quote
Old 02-28-2007, 04:39 PM   #2
treetop777's Avatar
Fantastic, this is easier indeed. Thanks.
treetop777 is online now   Reply With Quote
Old 03-10-2007, 11:50 AM   #3
polo6979's Avatar
np
95% done
Here is my project.
Old 03-10-2007, 12:03 PM   #4
That looks really easy! Im definately going to have to use that when Im set to go. Thank you so much!
DiLLyDiLL is offline   Reply With Quote
Old 03-10-2007, 12:17 PM   #5
Thanks for sharing that man!
spiro is offline   Reply With Quote
Old 03-11-2007, 09:26 PM   #6
DodgeCummins's Avatar
I am using win2k and have made a custom boot screen (that is mostly black) and my windows desktop is mostly black...
...but between showing the boot screen, and showing the desktop screen...
...it shows a blue screen for a few seconds...long enough to be annoying...
any idea how to make that screen black also?
current projects
DodgeCummins is offline   Reply With Quote
Old 03-12-2007, 08:18 AM   #7
efcmandan's Avatar
This may help:
http://www.pctools.com/guides/registry/detail/103/
efcmandan is offline   Reply With Quote
Old 03-13-2007, 04:05 PM   #8
Babushka's Avatar
Great info polo6979!
I have played with the eval of this software, but have a question that may be someone can answer. Looks like we can change/create new boot screen, login/welcome screen, and style schemes. But can we implement them with out installing the software on that PC? And also, If we uninstall the software, will our changed screens remain working? I hate to install extra s/w and run extra agents that will not be needed later, I'm sure a lot of people feel the same.
TIA
Babushka is offline   Reply With Quote
Old 03-14-2007, 08:04 PM   #9
dontpntpool's Avatar
That looks like its bloatware. There is much better solutions.
Quote:
It is possible to disable XP splash screen, which will slightly speed up the overall boot process. Be aware that removing the splash screen will also cause you not to see any boot-up messages that might come up (chkdsk, convert ... ), but if your system runs without any problems then it should not matter.
1. Edit boot.ini
2. Add " /noguiboot" right after "/fastdetect".
But if your set on using a gui and want to put your own pic use some freeware software like: bootskin or booter or bootxp
Here is more detailed info
NOTE: updates and service packs can replace ntoskrnl.exe replacing your bootscreen.
dontpntpool is offline   Reply With Quote
Old 04-22-2007, 07:37 PM   #10
polo6979's Avatar
TIA
You will need to software to do this but after you apply it just remove the software. It will leave the boot screen. I have installed and uninstalled this program on my carpc and it doesnt install any other crap and it completly removes when you uninstall it.
95% done
Here is my project.
Old 04-24-2007, 10:06 PM   #11
Quote: Originally Posted by efcmandan View Post
Awesome!
That looks like it will do what I needed, thanks!
...nope...all my settings were correct, but it is pulling the default info from somewhere else.
current projects
Old 06-15-2008, 11:37 PM   #12
polo6979's Avatar
this is a bump for the nubies
95% done
Here is my project.
Old 09-11-2008, 12:01 PM   #13
I'vetried this and created it, but not able to find the boot.ini anywhere on the computer using the search command....Windoes XP Proffessional..
rocsell is offline   Reply With Quote
Old 09-11-2008, 12:07 PM   #14
UPDATE...
I just restarted the machine and my bootup screen does come on, but just before that I get the IBM screen for 5 seconds that displays the IBM logo along with the option to get into the BIOS...anyway of getting rid of this?
Old 09-11-2008, 03:14 PM   #15
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Try typing 'change bios screen' into the search bar. You may be surprised what you find.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
FAQ: Touchscreens explained RedGTiVR6 The FAQ Emporium 1 07-21-2008 10:10 AM
Windows Vista W/nView! 97GST Operating System Optimization 8 04-01-2006 08:46 PM
Boot to Windows AND Frontend IntegraKarim The FAQ Emporium 15 02-27-2006 08:26 PM
Simple custom boot screen. no 3rd party software! knubile WinNT Based 58 06-15-2005 08:54 PM
Okay I got DOS boot done, but Windows splash screen??!?! Phat Justice Software & Software Development 2 08-30-2000 12:37 AM
