Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 03-05-2007, 08:13 PM   #1
TV and stuff in my VW bus
Hey, i'm new here, as you might have guessed. I want to put a tv, dvd player and xbox in my '71 vw bus, but i don't know where to begin. I'd like to know how to integrate it so that the sound comes throught the car's stereo. I also want to make a switch board to easily switch between devices. I have no idea what i need to do this, or where to start. any help would be greatly appreciated.
Agent_Orange is offline   Reply With Quote
Old 03-06-2007, 07:14 AM   #2
_
I would really suggest doing a bit of searching as all of the information can be found on this web site.
There is a how-to on the stereo located in the FAQ emporium as well as an entire sub forum about car audio.
As for a switch, you probably don't need to MAKE anything since I'm sure a switch board is already made.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 03-06-2007, 03:56 PM   #3
quantum's Avatar
Oh, that would be cool though. I had one of those vans eons ago, and they are just plain fun. Ride like ****, but fun. You could probably put an entire server bank in that thing!
Mine had this 4 ft long sunroof, with about a 3" handle you had to hand crank to open it. After a few hundred turns and a tube of Ben-Gay for the shoulder, it would open a few inches. Finally got smart and rigged it so I could put my cordless drill on it instead. It was the only VW Bus I knew of with a 'Power Sunroof'
Anyway, do as Red said and search your heart out, you'll find tons of ideas.
Good luck!
COMPLETE! - 2002 Cadillac DTS - Summer 2008
http://www.mp3car.com/vbulletin/show...-complete.html
quantum is offline   Reply With Quote
Old 03-06-2007, 04:50 PM   #4
thanks for the replys, i can tell this site will be an invaluable resource
If i got an lcd computer monitor, is there a cable i could get to hook an Video jack to it, so it would be like a tv?
Last edited by Agent_Orange; 03-06-2007 at 08:16 PM. Reason: Automerged Doublepost
Old 03-07-2007, 11:52 AM   #5
david69leonard's Avatar
Another thing that you can do is order a mod-chip for your x-box, then you will be able to swap the HD with a bigger one so you can put different emulators and roms on it, pls save your games to the HD, basically set it up like a carpc with some limitations of course...
david69leonard is offline   Reply With Quote
Old 03-07-2007, 07:07 PM   #6
AO. The first thing you might want to consider is upgrading to an alternator and adding a second battery to your bus. If your planning to use any of these when camping its a defenite must.
The stock generator in your bus is only 38 amps. And I'm not confusing the terms; its a generator, not an alternator. After the power all the car electronics take, you are not left with many free amps to run your car pc or other toys.
71 is a good year. Power brakes, screaming dual port motor. Is your bus a Westy?
Im currently fixing up a 68 Westy Weekender.
david_594 is offline   Reply With Quote
TV Tuner/FM Tuner tangeray Car Audio 5 06-17-2005 05:16 AM
What TV tuners ? tolisn Road Runner 36 03-31-2005 02:23 PM
ATI TV WONDER™ VE pci more stuff !!!! allenruble Classified Archive 2 05-31-2003 11:07 PM
What TV tuner card are you using to record TV shows? wysiwyg General Hardware Discussion 6 02-23-2003 11:44 PM
8.4" Touchscreen LCD, 7" Wide LCD & portable DVD player with TV Tuner nolmscheid Classified Archive 4 03-16-2002 01:32 AM
