Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 03-06-2007, 11:34 PM   #1
floating ground
Hi,
i dont know if i have this the wrong way around,but i am interested in finding out if my car has a floating ground on the stock harness,so are newer cars or older cars more likely to have a floating ground stereo?
Smartstradamus is offline   Reply With Quote
Old 03-08-2007, 04:29 AM   #2
Isolated grounds
Car stereo units have had isolated (non-earthed) audio spkr connections since the early 80's. This reason for this is twofold. One is to stop earth loops for noise etc, but mainly because the output stages in the radio are isolated from the spkr case which is normally connected to battery eth.
The units then need to have both the power and return wires run to the spkr or amp.
You can install an isolation unit between the spkr and the amp which then allows the spkrs to be connected to battery negative, but this can lead to problems. Easy to check. Connect multimeter from spkr neg wire to chassis. Is open reading then isolated. If short, not
mahrie
mahrie is offline   Reply With Quote
Induced noise/Ground loop trouble shooting guide. Will Albers Car Audio FAQ 111 09-24-2008 12:28 AM
Alternator Whine Only With Carputer tbird2340 Car Audio 25 06-29-2007 02:36 AM
Wiring Questions ViViper1 Power Supplies 8 11-13-2006 07:46 AM
I tried everything, can't get rid of this ground loop intense General Hardware Discussion 3 07-10-2005 08:58 AM
Pinout Color Codes / Tables gummybear General Hardware Discussion 4 05-12-2005 03:05 AM
