Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 03-18-2007, 10:35 PM   #1
digital dash question
hi everybody, im a newbie. anyway my question is, i have an 89 ford probe lx with a analog guage dash and i wanted to put in a digital dash from another probe of the same year, is it a simple swap or do i need to change the wiring connector to fit the digital dash, can anyone tell me what needs to be done to do this swap.
knightprobe89 is offline   Reply With Quote
Old 03-18-2007, 10:50 PM   #2
No promises, but I might be able to help if you can tell me what model the donor car and your car is: GL,GT, or LX.
Edit: After researching this, the answer is no, not without marjor parts swapping, at least other harness and connectors. The connectors are different and the pinouts are not even kind of close. PM me for a diagram if you like.
Last edited by h3rk; 03-18-2007 at 11:28 PM. Reason: found the information I was looking for.
h3rk is offline   Reply With Quote
Old 03-20-2007, 12:02 AM   #3
ok thanks, ill have to see if i can get the harness and connectors and try to make it work
Old 03-20-2007, 12:22 AM   #4
There may be more to it than that, the sensors (oil,etc) may be different. The best way to check is to take the diagram I have waiting for you, and look up each component that is connected in the circuit at a parts store (rockauto.com works well) and see if different components are listed for digital dash vs. analog. This could get expensive. I would spend much time planning this before going to gather parts. But, that's how I do everything.
SDPIF digital Coax into car audio pieces RedGTiVR6 Car Audio 25 Today 02:16 PM
Using Digital Mods while driving (IsSafe) question Aquaman DigitalMods (Scripts / API) 8 01-31-2007 01:38 PM
Accord lcd question - placing lcd deeper in dash mykolJay Fabrication 9 09-29-2004 01:02 PM
Question about the dash mount mikelee516 Classified Archive 1 10-24-2002 02:56 PM
