Go Back   MP3Car.com > Mp3Car Technical > Newbie
Old 03-19-2007, 11:19 AM   #1
briderx's Avatar
CarPC install on 96 Jeep Cherokee - Questions..
Okay, I know lots of people don't recommend installing a CarPC under the driver/passenger seats.. So, I devised a plan.. How about putting it in the center console? I was planning on doing this, using 1" risers (aluminum) to bolt the mainboard down to (no case). Build a custom lock box with air vents..
The items I SHOULD need are:
Mainboard/Proc
Ram
Hard Drive (already have 2.5" 20gb)
Monitor (7" Touch Screen - In-Dash)
Some sort of inverter??? (Suggestions????)
and the "Picto-PSU" or whatever that's called..
Is there anything I'm missing?
briderx is offline   Reply With Quote
Old 03-19-2007, 12:19 PM   #2
MySQL Error
MatrixPC's Avatar
Mainboard/Proc
Ram
Have you figure out why carPC under driver/passenger seats isn't an idea? If there is space for it why NOT? And I am sure you have plenty of space on the passenger side on the Jeep.
Said NO to the following "Pico PSU". For PSU, either DSATX, Opus, M1/M2-ATX. Inverter + Home PSU is okay if you don't have the cash, but not recommended.
BTW
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 03-19-2007, 02:06 PM   #3
briderx's Avatar
Thanks for the response.. I personally don't want one under there, specifically for this reason: Water.. I have had standing water in my jeep before (going through rivers/such..) PLUS, if I create some sort of box inside my center console, I won't have to fork over another $100+ for a case.
This may be a dumb question.. As I would NEVER use a home PSU in my car.. BUT, will I still need an inverter if I buy a DSATX or one of the others recommended? It seems like I wouldn't...
Old 03-19-2007, 02:10 PM   #4
_
Installing under the seat isn't a good idea in most any install so don't feel bad about your situation.
No - you just need the DSATX, that's it. It IS your PSU.
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Old 03-19-2007, 02:30 PM   #5
briderx's Avatar
NICE! So.. Looks like total (w/o monitor) will run me around 350.. That's just the beginning! Dance!
Old 03-19-2007, 02:39 PM   #6
david69leonard's Avatar
I had a 91 Eagle talon tsi, the pc fit perfectly in the middle console (with a lot of cutting) I just used the console as the case... I also used a 400W home powersupply with a 500W inverter and it all fit in there as well, of course that was before they came out with the M2
david69leonard is offline   Reply With Quote
Old 03-19-2007, 03:36 PM   #7
If you search, I don't remember who, but search Jeep Grand Cherokee and it'll show you that at least two, possibly more, have installed in the center console. Mine is installed where the cd changer would go.
1Munkey is offline   Reply With Quote
2001 Jeep Cherokee Limited shakes Show off your project 40 03-26-2007 01:05 AM
Mazda3 carpc install scote Show off your project 21 01-10-2007 08:22 PM
2000 Jeep Cherokee carputer install - worklog akula169 Show off your project 8 12-13-2006 01:33 PM
NewB Questions for Laptop Install PaulDePimp Newbie 0 02-09-2004 10:57 PM
1997 Jeep Cherokee - Custom In Dash SeeBQ Show off your project 26 11-13-2003 03:11 PM
