Hi there,
Really into what your doing here, I have wanted odb osx for ages now.
I'm having a bit of a problem compiling the programme.
Hoping maybe you could steer me the right way.
After typing 'make' this is what happens:
michael
bdgpslogger-0.4 michael$ cd build
michael:build michael$ cmake .. #
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Couldn't find libgps
-- Looking for XOpenDisplay in /usr/X11R6/lib/libX11.dylib;/usr/X11R6/lib/libXext.dylib
-- Looking for XOpenDisplay in /usr/X11R6/lib/libX11.dylib;/usr/X11R6/lib/libXext.dylib - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/X11R6/lib/libX11.dylib
-- Found FLTK: /usr/local/lib/libfltk.a
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/michael/Downloads/obdgpslogger-0.4/build
michael:build michael$ make
Scanning dependencies of target cksqlite
[ 4%] Building C object libs/sqlite3/CMakeFiles/cksqlite.dir/sqlite3.o
Linking C static library libcksqlite.a
[ 4%] Built target cksqlite
Scanning dependencies of target obdgpslogger
[ 8%] Building C object src/CMakeFiles/obdgpslogger.dir/database.o
[ 13%] Building C object src/CMakeFiles/obdgpslogger.dir/gpscomm.o
[ 17%] Building C object src/CMakeFiles/obdgpslogger.dir/gpsdb.o
[ 21%] Building C object src/CMakeFiles/obdgpslogger.dir/main.o
[ 26%] Building C object src/CMakeFiles/obdgpslogger.dir/obddb.o
[ 30%] Building C object src/CMakeFiles/obdgpslogger.dir/obdserial.o
[ 34%] Building C object src/CMakeFiles/obdgpslogger.dir/tripdb.o
Linking C executable ../../bin/obdgpslogger
Undefined symbols:
"_creategpstable", referenced from:
_main in main.o
"_creategpsinsertstmt", referenced from:
_main in main.o
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[2]: *** [../bin/obdgpslogger] Error 1
make[1]: *** [src/CMakeFiles/obdgpslogger.dir/all] Error 2
make: *** [all] Error 2
Any idea what to do now?
Thanks.
