Go Back   MP3Car.com > Mp3Car Technical > Engine Management, OBD-II, Engine Diagnostics, etc. > OBDII GPS Logger
Old 06-15-2009, 03:26 PM   #1
cgalpin is an unknown quantity at this point
Didn't get parsable data back for cmd 00:
Hi Guys
I'm having trouble getting data from my scantool. It connect, but I get "Didn't get parsable data back for cmd 00:" and things go downhill from there. I tried connecting at 38400 baud as well with no luck.
Here is what I get from --serial-log=slog
Code:
cgalpin@jaunty:~/tmp/obdgpslogger/bin$ od -c slog 0000000 A T Z \r x 374 370 370 377 017 0 1 0 0 \r 370 0000020 374 370 370 377 017 A T E 0 \r x 374 370 370 377 017 0000040 A T S 0 \r x 376 x 374 370 017 0 1 0 0 \r 0000060 370 A T Z \r 224 212 \v \b 373 003 0000073
thanks,
charles
cgalpin is offline   Reply With Quote
Old 06-15-2009, 04:48 PM   #2
Mod - OBDII GPS Logger forum
chunkyks is on a distinguished road
Binary garbage across the serial port. An easy way to know your baudrate's squiffy.
Try editing src/logger/obdserial.c around line 94. Before the tcsetattr, add the following:
Code:
cfsetispeed(&options, B38400); cfsetospeed(&options, B38400);
The way obdgpslogger works right now, it simply gets the serial port settings using tcgetattr, modifies the ones it cares about [canonical mode, etc], and writes those settings back using tcsetattr.
This assumes that your {serial port, usb device driver, usb-to-serial chip} are all Doing The Right Thing(TM) and negotiating stuff right. In practice, I'm finding that a lot of people have their ports set to 9600 or 38400, but the device is set to the *other* one
You could also try using stty to set the baudrate on the port before launching obdgpslogger [probably faster and easier than modifying code, come to think of it]:
Code:
stty -F /dev/ttyS0 38400
In future, I think I'm going to add command-line options to control the baudrate by hand. [My OBDPro device uses the LEDs when you power it on to tell you what baudrate it's set to]
Lemme know if that improves things
Gary (-;
chunkyks is offline   Reply With Quote
Old 06-16-2009, 02:15 PM   #3
Just for anyone following this, I really didn't make any progress with this. Gary and I discussed this in IRC and I think it's a ftdi driver issue. Even just doing a basic connectivity test with minicom barely worked, and never could get a proper conversation going. I did verify communication speeds and even managed to change the OBDPRos scantool to 38400, but it didn't help. Works fine with the windows software it came with on a real windows laptop.
So for now I am going to shelve it. I honestly don't care about put a computer in my cars with OBDII right now, and will focus on my non-OBD and OBDI trucks!
charles
iBusRR v2.0.5: 06/01/2008 BMW Doors/Windows/Lights control NEW RELEASE!! WaRFiElD RR Released Plugins 384 10-14-2009 11:44 AM
police laptop\radio frequency jdogg1583 Hardware Development 63 03-31-2008 05:32 PM
How can I send the GPS data back to my computer via GPRS?? virkom GPS 2 07-01-2006 06:39 PM
AutoTap ODB-2 cable... coleman Engine Management, OBD-II, Engine Diagnostics, etc. 18 11-29-2004 12:13 AM
VOICES Traffic Data stevieg V.O.I.C.E.S 85 05-31-2004 09:24 PM
