Problem compiling under Ubuntu 9.04
I followed the thread on here for doing this exact thing but it's not working for me. This is on an Asus eeePC 900A with Easy Peasy distro upgraded to Ubuntu 9.04:
dents@datalog:~/Desktop/obdgpslogger/build$ cmake ..
-- The C compiler identification is GNU
-- The CXX compiler identification is GNU
-- Check for working C compiler: /usr/bin/gcc
-- Check for working C compiler: /usr/bin/gcc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so
-- Looking for XOpenDisplay in /usr/lib/libX11.so;/usr/lib/libXext.so - found
-- Looking for gethostbyname
-- Looking for gethostbyname - found
-- Looking for connect
-- Looking for connect - found
-- Looking for remove
-- Looking for remove - found
-- Looking for shmat
-- Looking for shmat - found
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/lib/libX11.so
-- Found FLTK: fltk_images;fltk;fltk_gl;fltk_forms;/usr/lib/libSM.so;/usr/lib/libICE.so;/usr/lib/libX11.so;/usr/lib/libXext.so;/usr/lib/libm.so
-- Found GPSD: /usr/lib/libgps.so,/usr/lib/libgps.so
-- Found DBUS: /lib/libdbus-1.so,/lib/libdbus-1.so
-- Looking for include files HAVE_SIGNAL_H
-- Looking for include files HAVE_SIGNAL_H - found
-- Looking for sigaction
-- Looking for sigaction - found
-- Looking for signal
-- Looking for signal - found
-- Looking for ptsname_r
-- Looking for ptsname_r - found
-- Configuring done
-- Generating done
-- Build files have been written to: /home/dents/Desktop/obdgpslogger/build
dents@datalog:~/Desktop/obdgpslogger/build$ make
Scanning dependencies of target ckobdinfo
[ 2%] Building C object src/obdinfo/CMakeFiles/ckobdinfo.dir/obdrevconvertfunctions.o
[ 4%] Building C object src/obdinfo/CMakeFiles/ckobdinfo.dir/obdservicecommands.o
[ 7%] Building C object src/obdinfo/CMakeFiles/ckobdinfo.dir/obdconvertfunctions.o
Linking C static library libckobdinfo.a
[ 7%] Built target ckobdinfo
Scanning dependencies of target ckobdconfigfile
[ 9%] Building C object src/conf/CMakeFiles/ckobdconfigfile.dir/obdconfigfile.o
Linking C static library libckobdconfigfile.a
[ 9%] Built target ckobdconfigfile
Scanning dependencies of target cksqlite
[ 11%] Building C object libs/sqlite3/CMakeFiles/cksqlite.dir/sqlite3.o
Linking C static library libcksqlite.a
[ 11%] Built target cksqlite
Scanning dependencies of target obdgpslogger
[ 14%] Building C object src/logger/CMakeFiles/obdgpslogger.dir/main.o
/home/dents/Desktop/obdgpslogger/src/logger/main.c: In function ‘main’:
/home/dents/Desktop/obdgpslogger/src/logger/main.c:203: warning: assignment discards qualifiers from pointer target type
/home/dents/Desktop/obdgpslogger/src/logger/main.c:424: error: storage size of ‘msg_ret’ isn’t known
/home/dents/Desktop/obdgpslogger/src/logger/main.c:425: error: ‘OBD_DBUS_NOMESSAGE’ undeclared (first use in this function)
/home/dents/Desktop/obdgpslogger/src/logger/main.c:425: error: (Each undeclared identifier is reported only once
/home/dents/Desktop/obdgpslogger/src/logger/main.c:425: error: for each function it appears in.)
/home/dents/Desktop/obdgpslogger/src/logger/main.c:427: error: ‘OBD_DBUS_STARTTRIP’ undeclared (first use in this function)
/home/dents/Desktop/obdgpslogger/src/logger/main.c:434: error: ‘OBD_DBUS_ENDTRIP’ undeclared (first use in this function)
make[2]: *** [src/logger/CMakeFiles/obdgpslogger.dir/main.o] Error 1
make[1]: *** [src/logger/CMakeFiles/obdgpslogger.dir/all] Error 2
make: *** [all] Error 2
Which dumb thing did I do?
