Go Back   MP3Car.com > General > Off Topic
Old 05-17-2007, 11:28 AM   #1
It's not really that small...No, seriously.
judoGTI's Avatar
judoGTI is on a distinguished road
To get a PC fan to reverse direction?
Hey everyone, Im building my own laptop cooler and have question. I want to use a blower style fan to keep the cooler to a minimum size, but I need these fans to suck in, instead of their natural ability to blow out.
If I just switch the positive and negative wires will I accomplish this without any ill effect?
Here is a pic of the fan I want to use, just a typical blower style fan with a pos and neg wire to power it.
'02 GTI
[Routis '04] [Opus 90W] [160GB Maxtor HD]
[Lilliput 7" TS] [VIA M10000] [XMPCR]
[512MB RAM] [Custom housing]
[Deluo GPS Mouse] [E-MU 0404 Soundcard]
Progress Meter: [==============|] 99.9%
judoGTI is offline   Reply With Quote
Old 05-17-2007, 11:34 AM   #2
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
It depends on the fan , some fans have some sort of an electronic circuit in it , and if you plug it in backwards it doesn't work.
kevinlekiller is offline   Reply With Quote
Old 05-17-2007, 12:27 PM   #3
Super Moderator
xBrady's Avatar
xBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to behold
Flip the fan around.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 05-17-2007, 12:54 PM   #4
shiltz's Avatar
shiltz is on a distinguished road
Even if it does spin in reverse when you switch the pos and neg it will not move much air as the blades are designed to push air in one direction only, only way to reverse it is to take the fan out and flip it if posible.
VIA MII10000, 512mb, EVGA MX4000, Xenarc 700TSV, M1-ATX PSU
G.Skill 64GB SSD, Panasonic slimline slotload CDRW/DVD ROM
shiltz is offline   Reply With Quote
Old 05-17-2007, 01:52 PM   #5
psyrex's Avatar
psyrex is on a distinguished road
, but you can't take it out and reverse it. With a regular box fan, you can just point it in a different direction, but not the fan you posted.
psyrex is offline   Reply With Quote
Old 05-17-2007, 09:08 PM   #6
Bowel movement
jjh221's Avatar
jjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud of
lol, i was thinking the same but he wants the side vents prob to blow not suck.
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
jjh221 is offline   Reply With Quote
Old 05-17-2007, 10:09 PM   #7
Rub One Out
Motoko's Avatar
Motoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of lightMotoko is a glorious beacon of light
buy a left hand fan?
CarPC status: iPod, 3,456,217 songs so **** you
Motoko is offline   Reply With Quote
Old 05-17-2007, 11:59 PM   #8
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
that is just not true, a fan like that will reverse airflow with reverse rotation, as will most any fan, the blades are pitched at an angle that will cut & move air one way or the other..., if it was a squriel cage design then it'd be affected by housing etc, but not one like this...
turbocad6 is offline   Reply With Quote
Old 05-18-2007, 12:29 AM   #9
Old 05-18-2007, 02:17 AM   #10
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
It will probably move air, but not as much. The blades are designed to work in one direction. They have a slight curvature to them that will be reversed if working in the other direction.
Don't believe me? Just got and look at the blades on a fan to see the curvature.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 05-18-2007, 09:11 AM   #11
turbocad6's Avatar
yeah, the blade scoop, but that amounts to maybe a 10% difference in airflow, if that much even... it will still flow air in both directions no problem even though it may be optimized for one direction or the other...
Old 05-18-2007, 12:22 PM   #12
judoGTI's Avatar
Hmmm, damn. Does anyone know if they make 'blower' style fans that suck in instead of blow out?
'02 GTI
Old 05-18-2007, 01:17 PM   #13
Lowell is an unknown quantity at this point
I don't know that they make fans that suck vs blow, however you can just reverse the blade. I had to do this when I installed liquid cooling in my PC at home. It was a fairly simple operation I just unscrewed the fan and cover on the radiator flipped it and screwed it back on.
If this is your case fan and there is place to screw it in on the outside you could just mount it backwards on the outside.
Air cooling sucks anyway use liquid cooling. That's what I use, so efficient and cool.........................
Lowell is offline   Reply With Quote
Old 05-18-2007, 09:59 PM   #14
judoGTI's Avatar
After searching far and near, low and high, looks like I found the fan for me!
http://www.evercool.com.tw/products/nb_ma1.htm
A sucking blower style fan!
'02 GTI
Old 05-18-2007, 11:29 PM   #15
I see dead kittens
Quattro's Avatar
Quattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant futureQuattro has a brilliant future
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
ONINE PETITION: TomTom Navigator for PC bLindmOnkey GPS 19 06-07-2007 02:16 PM
Cold weather, chassis cooling fan problem blazini General Hardware Discussion 3 11-08-2006 07:55 AM
Turn the pc on from the boot NiN^_^NiN General Hardware Discussion 0 08-06-2005 12:42 AM
Is this possible? Routing HU into the PC then into Amp? m00ie Car Audio 21 07-22-2005 02:35 PM
PC / Vehicle interface bluelip General Hardware Discussion 7 07-15-2005 02:24 PM
