Go Back   MP3Car.com > General > Off Topic
Old 06-14-2007, 12:29 PM   #1
candlectj is an unknown quantity at this point
Air Condition Problem
Dear experts,
I have a 96 Honda Civic.
Recently, I replaced my Upstream Oxygen Sensor, in order to reach it, I tried to move the radiator. I unscrew one screw on the radiator, then I heard air releasing sound.
When I was done with the oxygen sensor, I realized my A/C was gone.
I went to the store and bought a recharging kit. But A/C is still not functioning right, I don't feel the difference.
I really need your help.
Thank you so much.
Teng
candlectj is offline   Reply With Quote
Old 06-14-2007, 12:36 PM   #2
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
to recharge the ac the right way, it needs to be vacumed first & then charged with the correct amount of freon, those little kits they sell can be ok if your system is just a little low to give it a boost, but to fully charge an empty system you should take it to a shop with the correct equiptment for this really.., a car like that may take around 2 pounds of freon give or take, doing this with those tiny cans can cost as almost as much as having it done right & won't work as good either..
turbocad6 is offline   Reply With Quote
Old 06-14-2007, 01:30 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Moved to Off Topic.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 06-14-2007, 02:29 PM   #4
Self proclaimed spoon feeder
TruckinMP3's Avatar
TruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud ofTruckinMP3 has much to be proud of
Sounds like you created a leak, that will need to be fixed.... then recharge.
TruckinMP3
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 06-14-2007, 02:58 PM   #5
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Could be a leak, but he removed a cap. That shouldn't really cause it to depressurise though. Was it the low pressure or high pressure side? High is the insulated one. I think they both have valves.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Xenarc Problem or Polarity Problem? mbkowns LCD/Display 1 01-06-2007 09:57 PM
audio problem tiburonputer General Hardware Discussion 0 08-11-2005 04:58 PM
YAOP (yet another Opus problem) Frankino Power Supplies 14 06-19-2005 12:17 PM
Lilliput Powering On/Off problem masch LCD/Display 0 05-09-2004 12:55 PM
power on problem ??? help please anyone Pingo1969 Power Supplies 26 04-07-2004 08:47 AM
