The MP3car.com Store
Go Back   MP3Car.com > General > Off Topic
Thread Tools Display Modes
Old 10-05-2007, 06:10 PM   #1
Raw Wave
lostreception's CarPC Specs
lostreception's Avatar
Vehicle: Chevy Van G20 and '06 Scion Xb
My Photos: (1)
Magical leprechans and Unicorns
I am a dj by hobby but my laptop sometimes bogs down when im using a piece of hardware called Serato Scratch Live which basically is an external device that listens to timecode fed into it and slows down speeds up and scratches a mp3 in realtime.
the Serato box runs off of the USB bus. I have it plugged into my laptop and I also have a IDE to USB2.0 converter with all my songs on it. on occasion it will bog down and freeze up slightly which isnt good.
So i was thinking of getting an NAS drive and running the mp3 hard drive off of that and leave the USB clear for only the Serato box. but I was looking at the specs on some of the NAS drives and they seem to have more thoroughput availible on USB. Im confused what to do cause NAS will offer 100MBps but USB offers 400MBps.
Should I get the NAS enclosure or will my results likely be the same or should i transfer the ide music to a sata drive and run that in the NAS. or try Sata and USB? whats a better option without spending too much and getting the most bandwidth?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
Last edited by lostreception : 10-11-2007 at 11:43 PM. Reason: So people answer if then know
lostreception is offline   Reply With Quote
Sponsored Links
Old 10-11-2007, 11:43 PM   #2
Raw Wave
My Photos: (1)
a little clarification on the title
seriously does anyone know or have an idea?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 10-12-2007, 05:08 AM   #3
My Photos: (0)
If you have a gigabit ethernet port, use that! If not Firewire. Firewire seems best for heavy transfers of files!
BiG K is offline   Reply With Quote
Old 10-12-2007, 08:31 AM   #4
Raw Wave
jjh221's CarPC Specs
jjh221's Avatar
Vehicle: 1998/Ford/Explorer
My Photos: (2)
definitely unicorns
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
jjh221 is offline   Reply With Quote
Old 10-12-2007, 08:50 AM   #5
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
It depends how your software reads the mp3's. Ethernet is ok for throughput, but a nightmare for access times (protocol dependable).
Maybe do a test with a bunch of mp3's on the internal disk, just to see if that solves the problem.
If so, use firewire if available on your laptop, or a pcmcia card with usb2/firewire/sata, depending on what you have...
Joachim
JC-S60 is offline   Reply With Quote
Old 10-12-2007, 11:23 AM   #6
Raw Wave
My Photos: (1)
jc the software has the whole mp3 available and cached once loaded in case i need to sample or scratch back to the beginning of the song
even ram might help now that i think of it but it already has a gig and is a dual core
so basically either way keeping both on usb is a bad idea right.
im a newb with dual cores its amd i wonder if theres a setting in the bios or something hmm
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 10-13-2007, 03:47 AM   #7
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
USB is very limited on bandwith, so your assumption of 1 on there is best. If you have the space for a PCMCIA card, Iwould get a firewire version. Seems like the simplest fix. Also make sure that dual core is running XP and not Vista. Vista bogs this stuff down, and its stupid security measures makes everything in general slower. So if you need speed...
Old 10-13-2007, 01:36 PM   #8
Raw Wave
My Photos: (1)
then i guess comes the next logical question is pata/ide gonna outshine sata/serial by all that much in this application you think?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Sponsored Links
vB code is On
Trackbacks are Off
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 80 07-16-2008 12:42 PM
Slim dvd drive problems. JAE 50pin to IDE at fault? 2k1Toaster General Hardware Discussion 17 08-16-2007 04:06 PM
SDK commands over the serial port ???? tolisn Road Runner 4 12-14-2005 12:03 PM
Looking for USB2.0 -> IDE Circuitry Fusion-One Classified Archive 0 08-09-2003 10:58 PM
Via Mini-ITX Epia 5000 serial port not working vash General Hardware Discussion 2 08-13-2002 08:48 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
