Go Back   MP3Car.com > General > Off Topic
Old 10-20-2007, 10:36 PM   #16
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by Quattro View Post
it pays for itself in the long run
How?
Does it go out and get itself a job deliverying pizzas or something?
Enforcer is offline   Reply With Quote
Old 10-20-2007, 10:37 PM   #17
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by 2k1Toaster View Post
I dont think changing 1 window will make too much of a difference. Expecially since during the winter I leave it open to cool down my room.
Anways, we were thinking of replacing all of the windows but that is probably another 2 to 3 years away. And by then I probably/hopefully wont be here.
you could try replacing it with a Linux
Old 10-20-2007, 10:50 PM   #18
Raw Wave
jjh221's Avatar
huh?
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
jjh221 is offline   Reply With Quote
Old 10-20-2007, 11:17 PM   #19
Confusion Master
Enforcer's Avatar
smatter you feel that you havn't used the aitch and you on your keyboard as much as the other letters or something?
Old 10-20-2007, 11:21 PM   #20
Raw Wave
jjh221's Avatar
que?
I GIVE FREE HUGS!
Buy Sell or Trade
Thank you
Forex
Old 10-21-2007, 02:07 AM   #21
Raw Wave
Quote: Originally Posted by Enforcer View Post
How?
...or maybe whore itself out, pay the rent itself that way as well as enough to buy cracks
Chris31 is offline   Reply With Quote
Old 10-21-2007, 04:58 AM   #22
Raw Wave
Rob Withey's Avatar
Do you think kde or gnome would be better for light transmission and openability?
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 10-21-2007, 12:06 PM   #23
TimmyM's Avatar
take a flexible, not stiff putty knife, and slide it around the inside and outside between the window frame and the stop. check to make sure there is nothing holding it like a nail or screw. sometimes people will do that for security. from the outside you should be able to get a pry bar like a wonder bar under it and start to pry up. if it stops slide the putty knife around it again. once it's up some grease in the tracks will help a lot.
supposely window replacement saves energy, therefor saves money. BUT in a house that old it might not even have insulation. That would be more of a savings then replacing windows. Specially in the ceiling. You can have it blown in or do it yourself. I believe Home Depot rents the blower and sells the insulation for it. Insulating the walls would require a professonal service.
TimmyM is online now   Reply With Quote
Old 10-21-2007, 01:25 PM   #24
Fusion Brain Creator
2k1Toaster's Avatar
Its a slide horizontal window, and as predicrted we got our snow today! 3" of fresh heavy packing snow over everything. Gave the window a good yank and out it came. I guess it had something to do with the weaher...
And the house was a model home when they built this area. Only house on the block with all hardwood floors, all insulated, finished basement, air conditioning, ect...
Thanks for the tips. I am going to go make a snow man!
Old 10-21-2007, 01:43 PM   #25
Confusion Master
Enforcer's Avatar
You want to make someone who can drive a truck and talk on the CB to a guy driving a Pontiac Trans Am
Onscreen keyboard gti Map Monkey 40 06-14-2008 10:00 PM
Alpine City Cruise Hell-Stopper RR Skins 170 02-22-2007 10:05 PM
iGuidance 2.x auto-run shortcut ziggyrama GPS 1 08-13-2005 06:05 PM
How to embbed any Application in RR ? guino RR FAQ 0 03-20-2005 12:35 PM
