Go Back   MP3Car.com > General > Off Topic
Closed Thread
Old 11-27-2007, 01:54 PM   #1
Check Engine Light Code
I have a 98 Honda Civic DX, and my check engine light went off after I filled my gas tank. Went to mechanic, he said my code was PO135 bank 1 sensor 1. He says for me to change the 02 sensor. Just wanted to know is this emergent to do?
tomboi is offline
Old 11-27-2007, 02:04 PM   #2
_
thread moved to OT....not sure what in the world this has to do with CarPCs...or car audio for that matter...
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline
Old 11-27-2007, 03:19 PM   #3
Hey, I accidently posted in the wrong section, okay? No biggie...
tomboi is offline
Old 11-27-2007, 03:41 PM   #4
muldrick's Avatar
No, no rush.
Now faith is being sure of what we hope for and certain of what we do not see.
muldrick is offline
Old 11-27-2007, 03:44 PM   #5
uhhh, you didn't tell me much of anything...
tomboi is offline
Old 11-27-2007, 04:11 PM   #6
Curiosity's Avatar
Any time you get codes like sensors, clear it, start the car, drive around the block, shut it off, then start it and drive again. If no codes, it was just a glitch. That might save you some $$.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline
Old 11-27-2007, 06:37 PM   #7
No offense, if you brought it to a mechanic to get the error code looked at, you should have got it repaired at same time, a sensor is easy to replace, it should be on the exhaust manifold in front of the engine of the civic.
My 2000 civic had same problem, just a sensor to replace.
Tony
tracker64 is offline
Old 11-27-2007, 08:35 PM   #8
I know it's easy to replace. Couldn't get it repaired at that time, no dinero. But does it affect the performance of the car?
tomboi is offline
Old 11-27-2007, 08:41 PM   #9
Fusion Brain Creator
2k1Toaster's Avatar
eventually it may screw up something depedning on how ECU dependant the car is. Bad readings so it makes bad decisions leading to bad engine.
But for someone who not only posted in the wrong section, but the wrong bloody forum you really need to tone down the attitude.
2k1Toaster is offline
Old 11-28-2007, 02:33 AM   #10
Reset the PCM, if it doesn't come back you will be fine. If it does disconnect the sensor and take a resistance reading between the two black wires on the sensor's terminal connector (the two opposite the tabs) should be 10-40 ohms.
h3rk is offline
Old 11-28-2007, 07:56 PM   #11
yes, a bad O2 sensor on the exhaust manifold will cause sluggish performance, and burn more gas. Every electrical component of an engine that causes the engine light to turn on must be fixed, keep in mind that one thing may affect the others, and in some cases, one defective part on a car will cause other parts to fail. Also, if your car is about 10 years old and if a cop stops you for a routine check or whatnot, and that Engine light is on, they could send you for inspection.
Tony
Old 11-29-2007, 07:04 AM   #12
muldrick's Avatar
You asked "Just wanted to know is this emergent to do".
I replied.
muldrick is offline
Closed Thread
FAQ: LCD Technologies dontpntpool LCD/Display 4 03-15-2007 12:20 AM
how many post whores does it take to change a lightbulb? TyBong Off Topic 22 01-05-2006 08:26 PM
Adding text-to-speech functionality to Media Engine skippy76 Media Engine 14 04-19-2004 01:38 AM
Adding file syncronisation to Media Engine skippy76 Media Engine 7 03-26-2004 11:01 PM
PC tied into Engine Computer > Check it AshsZ General Hardware Discussion 8 01-06-2003 07:47 PM
