The MP3car.com Store
Go Back   MP3Car.com > General > Off Topic
Thread Tools Search this Thread Display Modes
Old 12-04-2007, 06:43 AM   #1
My Photos: (0)
Network Bandwidth Limiter
Hi guys do you all know or came across any software so that I can manually limit folks that connect to my wireless network?I would like to setup a wireless access point at home so that I can have close neighbours connect to it.But I would like a software to control each one's bandwidth so that they won't suck all of my speed....Can anyone link me up?
platinumsteel is offline   Reply With Quote
Sponsored Links
Old 12-04-2007, 09:47 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
That would be a function of the wireleess router or access point.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 12-04-2007, 09:56 AM   #3
My Photos: (0)
Well I did some googling around and I was able to find a couple software claiming to do the job...network bandwidth controller,and some others talked about bandwidth shaping.so i am still kinda confused.
Old 12-04-2007, 10:46 AM   #4
My Photos: (26)
If you have a server that acts as a gateway or firewall, then this could be useful.
But on a typical home network this isn't the case.
Yes, there's "packet shaping" software out there, but it's typically cost-prohibitive for a home user, as these are designed for a large scale network, typical of a large corporation.
Also, since this has nothing to do with vehicle computing or software associated with a vehicle computer, I'm moving the thread to Off Topic.
My Worklog
Old 12-04-2007, 04:09 PM   #5
pbarrette's CarPC Specs
Vehicle: 92 Miata - 02 Miata SE
My Photos: (0)
Hi platinumsteel,
First, get a wireless router that has QoS capabilities. I like the Buffalo or Linksys routers that can run DD-WRT.
If you have DD-WRT, then you can set your QoS to prioritize by IP or MAC address, as explained http://www.dd-wrt.com/wiki/index.php...f_Service]here.
Any router with QoS should be able to handle this task. Just give your IP's a higher priority than your neighbors. You should also assign static DHCP leases for your computers if you aren't assigning priority by MAC address.
pb
pbarrette is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Network Stumbler Plugin DarkSlice Centrafuse 0 08-31-2007 08:22 AM
Network Performance/Security Woes cMags Off Topic 12 02-18-2007 03:48 AM
mappoint wont install on network chewEboy GPS 4 01-24-2006 05:39 PM
Network connection detection in 1.12 ecoleman Centrafuse 1 01-24-2005 04:34 PM
Wireless G - Wire'd Network Problems (Remote Desktop) nFiniteTuning Wireless Communications 5 01-01-2005 06:34 PM
Sponsored Links
Ad Management by RedTyger
