Go Back   MP3Car.com > General > Off Topic
Old 02-29-2008, 11:59 PM   #1
tominated is an unknown quantity at this point
Looking into building a HTPC, would this work?
Hi all,
I'm thinking of building a HTPC so I can get rid of the dvd player and set-top box. I have scoured the web for good parts that are cheap and found a good combo, but what i need to know is if they are all compatible (i'm not sure with the mobo).
MSI 945GCM5-F Mobo
Intel Core 2 Duo E6550
2gb PC-5300 corsair ram
2 Samsung 500GB SATA hard drives (in raid 0)
Galaxy GeForse 9600GT Graphics Card
PPioneer BDC-S02BK Blu-Ray Drive
Antec Fusion V2 Case
Vista home Premium 64bit (for media center)
DLink DWL-G550 Wireless adaptor
AOpen Cobra AW-870LP Sound Card (for the S/PDIF connector)
DVICO Fusion Dual 4 TV Tuner (2 hd channels at once ftw!)
Would this work and do you think it is any good?
BTW: It's only going to cost $1730 Australian (around $1610 american) to build!
Planning {[][][][][][][][][][]} 100%
Funding {[][][][][][][][][][]} 100%
Construction {[][][][][][][][][][]} 60%
tominated is offline   Reply With Quote
Old 03-01-2008, 12:36 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
I think it is way overkill for a HTPC. A P4 can do a good HTPC no problem.
Also your video card is overkill and wont do you any good. Video cards like that are meant for gaming and a high number of pixel shaders and such wont help you rendering video.
If you are wanting to record 2 HDTV streams at the same time, while outputting an HDTV stream, you may need some good CPU power more than a P4. And today, the best bang for your buck desktop wise is a cheap Quad core.
I have an HTPC running a 2.2Ghz P4, with 512Mb RAM, and outputs basic HD (component/composite I get them mixed up. It is the 5 pronged ones with 3 video 2 audio) and it never skips a beat. Total cost including case/psu was under $200. Internal storage of 20Gb but streams media from my server PC (2.5Tb of space).
So a media PC doesnt have to be so complicated.
Old 03-01-2008, 12:55 AM   #3
brendan is an unknown quantity at this point
as 2k1toaster said you don't need a super warp 10 computer, mine is only a 1.8 amd with 700ish meg of ram. i stocked it with about 1Tb of space and just a simple haupauge tuner and an ati card that could do component video. im just using the onboard s/pdif for sound and it's all good.
id like to make the switch up to HD recording soon, but im in no rush, its outputting to a big veirra and looks fine in 1080 whatever resolution, i can sit nearly right infront of it and its still good, although not quite a monitor but everything is readable.
brendan is offline   Reply With Quote
Old 03-01-2008, 01:39 AM   #4
thing is, I want to use it for gaming on the plasma (i really like all the new games like crysis, ut3 and cod4. It's not just a regular HTPC. I really want to use it for average pc tasks as well as home theater usage. Also, It's easier to turn it into a gaming pc later if i want to.
Stealthy surfing at work? e_z_street Off Topic 15 10-07-2009 03:30 AM
Does FluxMedia own rights to our skins? justintime CF Skins 13 09-03-2006 08:22 PM
Allbrite and controller work with RCA but not VGA alti LCD/Display 22 01-05-2005 01:47 PM
Frodo: Work Harder, Work Faster.. hevnsnt FrodoPlayer 13 09-24-2004 04:09 PM
Will the Toshiba LTM10C021 (10.4") LCD work ok with an AD2 (standalone) controller? pooshda LCD/Display 4 11-18-2002 09:59 PM
