Go Back   MP3Car.com > General > Off Topic
Old 03-18-2008, 06:56 AM   #1
Mac help needed...
OK well im a novice to mac. My friend who has a iMac G5 wanted to upgrade to the new leopard. SO i went over there today to try an upgrade the OS.
I tried to "restore" an image in disc utility.
So In Disk Utility I went to RESTORE, for SOURCE I put the osx leopard DVD . And for the Destination I made it the Mac HD. I figured that it would create animage file. BUT it did not, what it did was, it made the MAC HDD the Leopard Installer DVD. So now I restarted the Mac and it keeps trying to load the Leopard because it is acting as the Leopard install. While the restore was "COPYING" i saw that in FINDER under the harddrive, an icon was created called OSX Leopard install DVD.
Questions:
1. Is there any way I can somehow fix this. I cannot even get on to the desktop.
2. Is there anyway to view the contents of the HDD if the OS install disk is inserted?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 03-21-2008, 10:09 PM   #2
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
I don't understand why you tried to restore anything? Just put the Leopard disk in and run the installer.
What you did was take the image in the DVD drive and put it on the hard drive. I'm not sure if that wipes the disk or not, but I think it does.
To read the HD, boot the computer with the Leopard DVD in it. Press and hold 'C' immediately after starting. It should boot to the desktop from the DVD drive. You ought to be able to access the hard drive from that point.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 03-22-2008, 03:23 PM   #3
Well that's bad - REALLY bad.
All you buddy's data is now gone, it's effectively wiped clean.
Boot the mac with the DVD in the drive and hold down the C-key, install normally.
// Per.
zapro is offline   Reply With Quote
Old 03-22-2008, 04:18 PM   #4
Mac Car Moderator
kandyman676's Avatar
I really hope you had your friend take a BACKUP before you started any of this...you just wiped his HDD.
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
kandyman676 is offline   Reply With Quote
Old 03-22-2008, 10:27 PM   #5
Problem SOLVED... I just formatted the drive and installed OS X Panther. Its ok because I saved all of his data b4 i did anything. He bought a 250GB HDD and 2gb or memory. I installed everything and loaded Leopard on the new drive. Everything is good... Thanks for your help guys.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-23-2008, 07:59 PM   #6
Mac Car Moderator
No problem. Leopard seems to love a new harddrive better than trying to upgrading an existing install from my experiences.
Glad to here your friend is up and running.
Old 03-23-2008, 08:55 PM   #7
I have been a PC guy for a while now. But after learning a bit about Mac I really want to get a nice new iMAc now.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-24-2008, 08:18 PM   #8
Mac Car Moderator
Hey, that's how most of us start...I use to hate hate macs when I worked in a design shop as the Windows admin and web programmer. It wasn't until the intel chip change I started to like them and actually wanted one. Actually certified for the 10.4 desktop and run an Xserve RAID at work with the rest of my 400+ Win 2k3 servers.
Help: MAC Mini - Carnetixs P1900 issues Firebird2 MacCar 6 12-21-2007 04:18 PM
Mac mini (Intel) and CNX-P2140 atl MacCar 9 08-19-2007 12:26 PM
Installing Mac Mini in My 05 Alti SER Vitulla Newbie 1 05-23-2007 11:55 PM
Garmin announces Mac GPS support for everything! skizot MacCar 11 01-31-2006 03:37 AM
Hot Rod Company to start incorporating Mac Minis stacheldraht MacCar 4 02-01-2005 12:25 PM
