Tests/Procedures:
1. Disconnect the set timing connector or ground the Tan/Black bypass wire.
2. The check engine light should come on and
code 42 should set.
3. If the engine stops stalling, disconnect the pick up coil connector at the Ignition Control Module (ICM).
4. Check acv output from the pick up coil while cranking the engine at a normal cranking speed.
5. If output is less than 700 mv replace the distributor shaft with a new one.
6. If the engine still stalls with the bypass open or shorted to ground see if adding alternative fuel to the throttle body helps.
7. Wet down the coil and coil wire with water and see if the stall is induced at a higher RPM.
8. Check for a loss of injector pulse or spark.
Potential Causes:
Distributor shaft
Coil
Coil wire
** Confirmed Fix **
Distributor
