Quote: Originally Posted by
2k1Toaster
So I looked at portable air conditioners. Those are frigging expensive. So no.
There cheap here, around $300 - I was replacing the $100 window units every
year they just cant hold up to the rain, dust and dirt were I live, the fan motors
burn out, so I got a 10,000BTU Portable unit, seams to work fine,
Ether unit will make lots of water, its a steady drip, and if you ever left the water
drip in the tub or sink with the stopper in, over night, it over fills, so its a good
amount of water coming out of the AC
I would just get a cheap Portable unit, but even with the portable unit, you have to
install something like a dryer vent, and a drain,
If you do go with the window AC, your going to have to use painted plywood, and use
silicone to water proof around the edges, and the window AC needs to be able
to drain, so it needs to be at an slight angle for that,
I was always worded about the AC falling out, or something or some one getting in, so
I put screws threw the plywood into the window and window frame, all the way
around, you can use a small drill bit to pre-drill the holes, it helps a lot to do that
keeps the wood from splitting, just use slightly larger screws than the drill bit
