The MP3car.com Store
Go Back   MP3Car.com > General > Off Topic
Thread Tools Display Modes
Old 05-21-2008, 08:56 AM   #1
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (90)
Network ports quit working on my router?
I'm not sure when this happened since I mostly use wireless...mostly like 99.9% of the time.
I have plugged in an IP phone (which they configured for me before they sent it to me) and I've plugged in my laptop. Neither device can see the network. The laptop tells me that a network cable is unplugged while the phone tells me it can't find the network.
I'm not sure where to start on this. I've rebooted the router (soft), it didn't change anything. I've plugged the laptop directly into the modem and I get a connection just fine. I've even tried directly plugging in both the phone and the laptop to the router instead of using the ports on the wall that we added, still nothing.
Where do I need to start troubleshooting? Is there something in the admin panel that might help with this?
Thanks in advance!
Jan Bennett
PLEASE do NOT PM/Email/IM me asking me to spoon feed you. Please post on the forums! Chances are, someone else has or will have the same questions.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 05-21-2008, 09:09 AM   #2
danielkh's CarPC Specs
danielkh's Avatar
Vehicle: 2004 Nissan 350Z
My Photos: (0)
Thanks in advance!
Jan, what brand of router? The bad news is that if you plug in a cable to the router and it says a cable is unplugged, the chances are the router is dead as there is no power at the ports.
My opinion is my own
My Current Setup is Here
danielkh is offline   Reply With Quote
Old 05-21-2008, 09:09 AM   #3
Raw Wave
TruckinMP3's CarPC Specs
TruckinMP3's Avatar
Vehicle: '02 suburban with quad captain seating
My Photos: (0)
You might try 'resetting' the router to factory default and reconfigure from that point.
Generally pressing a button recessed in a hole on the router with a paper clip will do that.
It is possible the ports are nonfunctional.....
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 05-21-2008, 09:14 AM   #4
danielkh's Avatar
My Photos: (0)
That's where I was going to go, but some routers are different. On most, you hold the reset button for more than 10 seconds. If after that, when plugged in, it says that a cable is unplugged, it's time for a new router. Even if a network is dead, no other cables even plugged into it, you will not get the "cable unplugged" as it only looks for communication power to the router, not a network signal.
Routers are cheap though.
Old 05-21-2008, 11:18 AM   #5
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Time to get a N type draft 2.0 router then.
2k1Toaster is online now   Reply With Quote
Old 05-21-2008, 11:30 AM   #6
danielkh's Avatar
My Photos: (0)
Nothing like overkill. A router that is faster than the internet.
Hey, not a bad price on them though! Might go that way myself now.
http://cgi.ebay.com/Alink-300M-Draft...QQcmdZViewItem
Old 05-21-2008, 03:11 PM   #7
_
My Photos: (90)
I could justify it if my laptop could utilize the technology...but no point in spending the extra $$ when i'm going to probably end up replacing it yet again before I get a new laptop...lol
A while back, after being gone for a weke and a half, we came home to one side of the house being without power...really strong storm came through and a lightning strike had caused a breaker to switch on that side of the house. Absolutely NOTHING seemend to be wrong over there....except now I'm thinking the router took the hit...
damn! guess I'll be buying a new router.
It's a Linksys fwiw...wireless G.
Jan Bennett
Old 05-21-2008, 05:16 PM   #8
2k1Toaster's Avatar
My Photos: (1)
Those linksys routers are awesome. Especially when you load some of the newer non-linksys firmware on there. So many simultaneous connections it makes me drool.
And @daniel:
The point of a super speedy router is for internal connections. Live streaming HDTV throughout the house. (or lots of voip calls since draft 2.0 calls for voip and video streams to have a higher priority with bandwith. So it will auto-scale general browsing down, and increase high priority channels.)
Old 05-21-2008, 05:33 PM   #9
danielkh's Avatar
My Photos: (0)
And @daniel:
I run a couple of those "aftermarket" wrt54g routers you speak of. lol
I have everything hardwired around the house and the only real "wireless" is my laptop and the car. But I can see where those would be "fun" to have around.
Old 05-21-2008, 05:35 PM   #10
2k1Toaster's Avatar
My Photos: (1)
I've got one staring me in the face right now. I am actually just on Newegg now buying the new dual band 802.11a/b/g/n 2.4Ghz/5.0Ghz linksys router now. It looks like something darth vader would own.
Sponsored Links
Old 05-21-2008, 05:36 PM   #11
_
My Photos: (90)
See, I just don't have anything that can utilize the higher speeds, even between computers...not yet anyways...so the extra $5 or $10 just isn't worth it just yet for me.
However, once I get a media PC going, then that's a different story!
I actually wasn't aware of the other firmware downloads...links?
Jan Bennett
Old 05-21-2008, 05:36 PM   #12
danielkh's Avatar
My Photos: (0)
link?
edit: Found it! Dayum! Definitely darth vadarish
http://www.newegg.com/Product/Produc...nksys%2brouter
Old 05-21-2008, 05:38 PM   #13
danielkh's Avatar
My Photos: (0)
This will give you a bit more information. I run dd-wrt.
edit: The link would help, huh......
http://www.wi-fiplanet.com/tutorials...le.php/3562391
Old 05-21-2008, 07:55 PM   #14
Raw Wave
jjh221's CarPC Specs
jjh221's Avatar
Vehicle: 1998/Ford/Explorer
My Photos: (2)
1. connect to your router through your internet browser. Look to see if you can test anny connections to your router.
2. go into your laptop start -run - type "cmd" press ok- then type "ipconfig"
3. go back to your router and see if you laptop matches an ip that your router has set a range to. ie. 192.168.0.1-192.168.0.5
4. if your laptop is not within that range then type in run - cmd - "ipconfig /release" to release that ip. Then type "ipconfig /renew"
if you dont feel like doing those steps then.... just do
start -run - type "cmd" press ok - then type "ipconfig /release" then "ipconfig /renew"
if that does not work... then we will give your laptop an ip within the range of internal ip's set by your router.
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
jjh221 is offline   Reply With Quote
Old 05-21-2008, 08:00 PM   #15
danielkh's Avatar
My Photos: (0)
2. go into your laptop run - cmd and ipconfig
If she is getting "network cable unplugged", would the above steps do anything? There is no network there or even power for a network. If it is an IP issue, wouldn't you get the little terminals with the yellow triangle and exclaimation?
Sponsored Links
vB code is On
Trackbacks are Off
CF quit working v8focus1 Centrafuse 0 07-24-2006 05:58 PM
File Transfter USB Cable Or Etherent. neither is working for me- please help aamrtin_723 Newbie 3 02-11-2006 11:34 PM
how to get wired network working again Dave_Perth WinNT Based 8 12-02-2005 11:08 PM
So my antenna quit working... Jstarko0329 Wireless Communications 1 05-10-2005 09:49 PM
one of my USB ports is not working. Projekt 8E General Hardware Discussion 4 02-23-2004 05:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
