Quote:
I don't have fold-down rear seats
Supermatty,
Do you have pics of your setup? I have a 2001 mali. Try checking the trunk just under the rear deck. On mine, there are straps that you pull to release latches that allow the seats to fold down. I would use the foam strips like Mears said and use foam for behind the license plate. If you want to make the whole trunk rattleproof on the cheap, you can use that asphalt based roofing paper from Home Depot instead of dynamat b/c it is basically the same stuff. I have my underbody sprayed with this stuff that dampens sound from road noise. That works pretty good too.
