Go Back   MP3Car.com > General > Off Topic
Old 02-16-2009, 06:31 PM   #1
Nukeb32dc2's Avatar
Nukeb32dc2 is on a distinguished road
4 Pin Amp output to 3 Pin headphone jack?
So this one is stumping me and I am wondering if any of the smarties on this forum can help:
I have a four pin amplified audio output on a prototype motherboard and I am looking to convert this to a 3 pin output so I can then attenuate and use standard headphones.
The one caveat is that the amplifier is push/pull. Therefore, there are no grounds- AC is fed to each speaker as the polarities have opposite sin waves. I understand they make 4 pin headphones but this will not suffice. Using one channels ground will not work either as it sounds quite distorted.
Is this possible? If anyone can point me in the direction of a component or circuit that would do this I would be SO greatful! It seems simple but in reality....its over my head!
Nukeb32dc2 is offline   Reply With Quote
Old 02-16-2009, 06:33 PM   #2
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
This is exactly what a ground loop isolator does - it isolates the grounds.
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 02-16-2009, 06:47 PM   #3
Nukeb32dc2's Avatar
Thanks but I am not looking to insulate grounds; I am looking to create a common ground and 2 positives (one + for each channel) from a four pin push/pull output configuration with said limitations. Sorry if I wasnt clear and thank you very much for chiming in.
Old 02-17-2009, 04:03 AM   #4
Raw Wave
Rob Withey's Avatar
Yep, and you can do this with a ground loop isolator.
Connect your balanced lines into the inputs. Tie the grounds of the outputs together for your common ground. The two remaining outputs are your positive lines.
PC Motherboard to 1 amp or 2? hanzacra General Hardware Discussion 5 11-27-2007 03:41 AM
BMW E46 Owners with DSP systems and no HU edrock200 Newbie 21 12-16-2006 12:21 PM
Mini ITX board RCA output to Amp Daljsd General Hardware Discussion 6 07-26-2004 05:05 PM
amp for EPia-10000M audio output loscooby General Hardware Discussion 0 02-08-2004 04:49 PM
PW-60 max amp output? Logan Power Supplies 1 09-10-2003 04:44 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
