Go Back   MP3Car.com > General > Off Topic
Old 03-23-2009, 03:13 AM   #1
Aboliton is an unknown quantity at this point
In-car spud cannon
Hello all, so my plan is to mount two potato cannons in a free area where my fog lights would go, as shown in the photo.
For my ignition system I'm using ignition coils and spark plugs so thats all rather easy.
I've run into a problem however, with supplying fuel to the chamber. My original plan was to use a solenoid to control the flow of air from a butane/propane canister, but after 4 hours of looking I couldn't find appropriate parts. The next plan was to use a solenoid to press open deodrant can for a predetermined amount, that however isnt working well.
Does anyone have any suggestions for another method that isnt too expensive or complicated, it would be much appreciated.
Aboliton is offline   Reply With Quote
Old 03-23-2009, 04:33 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
you can't be serious???
Well anyways, since you have gas in your car already, why not a fuel injector of your gas line?
Old 03-23-2009, 05:16 AM   #3
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
Haha, awesome, just don't get caught.
malcom2073 is offline   Reply With Quote
Old 03-23-2009, 05:45 AM   #4
Crinos is an unknown quantity at this point
Not sure if I would assist you in this.. it might be my rear beeing hit by two potatos
But.. You could go for a CO2 spud...
There's ALOT of spud reading on the net.. just google it
Crinos is offline   Reply With Quote
Old 03-23-2009, 06:08 AM   #5
hmm, i'll read up on that, the only thing im concerned with is the confined space, might not fit >.>
Also doubt i'll be shooting you, i'm in aus
Old 03-23-2009, 11:38 AM   #6
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Meddler : Watchout!
Enforcer is offline   Reply With Quote
Old 03-23-2009, 01:02 PM   #7
Injector's Avatar
Injector is on a distinguished road
ask and you should recieve
http://www.nitrousdirect.com/solenoids.html
Injector is offline   Reply With Quote
Old 03-23-2009, 10:13 PM   #8
koolmoedee is an unknown quantity at this point
hahaha what model car is that? looks like a magna to me, i would love to see this in action when its up and running, here's a pic of my projectile system
i use it for passenger control keeps them quite
1993 Mitsubishi Verada
My Ride
koolmoedee is offline   Reply With Quote
Old 03-23-2009, 10:34 PM   #9
stealinfool's Avatar
stealinfool is on a distinguished road
Nice.
I'm using metered propane w/two manual valves.. this may work with auto valves.. basically so one lets the gas into a pipe that measures out a certain amount (you only want a certain ratio, otherwise no boom) and once that closes the other allows gas into the chamber. I use a bbq ignitor with a 12v battery.
Honestly you'll be better off using compressed air or CO2. Less likely to catch something on fire in case of an accident.
Also, keep in mind that a good chamber - barrel ratio is key to efficiency
I want to mount one to my 4wheeler though... a bit more likely to get use
DON'T PANIC.
Previous install pics in 2k3 S10
Project CarPc V2
stealinfool is offline   Reply With Quote
Old 03-23-2009, 10:51 PM   #10
Bowel movement
jjh221's Avatar
jjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud of
brilliant!
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
jjh221 is offline   Reply With Quote
Old 03-23-2009, 11:43 PM   #11
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
This is awesome but I'd advise dropping the fuel and using compressed air due to the fact that you don't want a rolling inferno if something goes wrong. Not that I speak from past life experience but if you have a carpet tube duct taped to your car hood and it's designed for the passenger to load a Roman Candle into it and he accidentally loads it backwards and it shoots into the car and ignites the rest of the fireworks in the car, you've got a pretty big issue. Better to go with compressed air instead of fire.
You can drive the compressor from the car's electrical system, trigger the solenoids with a fusion brain and you are golden!
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 03-24-2009, 02:14 AM   #12
the only issue i can forsee with using compressed air is the space limitation, i only have about a 30x12cm (12"x8" roughly) and i'm not sure where i could fit the compressor.
At the moment I'm considering going to the wreckers tomorrow and grabbing two injectors and trying to find a solenoid valve that can split between two outputs. The plan is then to connect it after my fuel pump and use a capacitor shutoff circuit to control the exact amount i'll need.
This wont be an issue to my normal driving as I run a duel fuel system, not sure if its popular in America and elsewhere but here in Aus it's fairly common to get LPG conversions which is a lot cheaper than petrol,
And yeah a Magna it is, wish I had a verada though
Old 03-24-2009, 03:13 AM   #13
Is your spud guns going to be magasine fed, so you can fire multipletimes with the same gun?
If not, you can have CO2 canisters, that you connect to the guns... the canister can be where ever you see fit. And when you have run out of CO2, you can disconnect it, and connect a new one, and refill the first one....
Like you would while playing Paintball
Old 03-24-2009, 03:23 AM   #14
Well, I've reconsidered the petrol idea, i don't want to screw stuff around with my engine, i'm considering the pneumatic idea. The thing with that is, I've never built a pneumatic one, and i'm not sure what the pressure limit on the pvc have is, also, I'm finding it hard to 12v solenoid valve with decent pressure
Old 03-24-2009, 06:27 AM   #15
Generally SCH40 PVC (smaller diameters) has been used for shop compressed air lines...
But here's a cool chart for ya
Considering how difficult it is to make a truly "magazine" type of feeding system, it's likely you'll get one shot at a time. This should allow you to have something like a 5 gallon portable air tank that you'd fill up from time to time... it would in turn pressurize a PVC chamber up to a certain PSI via one valve. The next valve would allow the pressure to escape the barrel, propelling the ammo.
Here's another site full of good stuff
DON'T PANIC.
Project CarPc V2
iPod-based Car PC R3N3G4D3 Newbie 12 03-10-2009 09:56 PM
Please commont on a n00b's design idea of a do-it-yourself car audio system Zta Newbie 5 03-06-2009 05:15 PM
What's your dream car? Aaron Cake Off Topic 172 10-02-2007 08:34 AM
In a real PC car struggle markland556 Off Topic 10 06-27-2007 12:36 PM
First Car PC Questions - Pretty Long Post Sorry :D [56k death] FiReToY Newbie 9 06-08-2006 06:15 PM
