Go Back   MP3Car.com > General > Off Topic
Old 09-19-2003, 01:35 AM   #1
Ashlawn Kemling's Avatar
Ashlawn Kemling is on a distinguished road
Blown Engine Repair
Now this isn't your typical car engine... it is your typical 11hp Briggs & Stratton lawn mower engine. The piston rod snapped into several pieces, one of them slamming into the crank case wall right next to the starter motor. It only cracked the metal and pushed it out a little. I pounded it back flat. The question is, if I get it welded up, insides cleaned, and the piston rod replaced, would it work?
I know you know don't need compression in the crank case, just need to keep the oil from leaking.
Ashlawn Kemling is offline   Reply With Quote
Old 09-19-2003, 01:48 AM   #2
carabuser's Avatar
carabuser is on a distinguished road
well, just one question, how the hell did you manage to break that thing?? were you racing it??
carabuser is offline   Reply With Quote
Old 09-19-2003, 02:19 AM   #3
Actually, I HAVE raced it in the past.... but the thing is twenty years old. That and it was trying to move a flat tire backwards up a hill.
Old 09-19-2003, 03:05 AM   #4
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
probably, but while you are at it, go ahead and do a rebuild with new rings at least, since it's so old, it could use some new life in it
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 09-19-2003, 10:51 AM   #5
pcman
these engines will run forever get the block welded up and it will be fine i got a friend that workjs at a gokart center and they use 9hp honda engines they crack on average a block a week and get em welded up and they keep going stronger than before
cheers
pcman
colecting new parts
installing into new toy
1975 td cortina wagon
12.1" lcd touchscreen
10.1" lcd
just the essentials :)
arr the fun starts again
pcman is offline   Reply With Quote
Old 09-28-2003, 07:18 PM   #6
SOBIL's Avatar
SOBIL
while youyr at it youy should go for a bigger bore, port it out, high flow reid valve, lightend flywheel, nitrogen hardend piston, decomp plate to 12:1, and nice big garret on the side. you'll have to replace your welsh plugs coz you'll prolli end up with more pressure in your crankcase than in your cylinder. lolz =[]
http://iamnot.azn.nu
SOBIL is offline   Reply With Quote
Old 09-28-2003, 08:47 PM   #7
What did you say?
Old 09-28-2003, 09:10 PM   #8
SOBIL's Avatar
SOBIL
whobwhobwhobwhob. whurrrrrrrooaaar. =======[8-8]
Fully sick mario motors here mate.
We up the boost on anything with a hairblower
<SING>
come on, come on it's not hard to learn,
come on, come on it's called a handbrake turn.
Oh ladies
</SING>
