Quote: Originally Posted by cafn8
I'm more concerned about the effects of adding a 50 ohm resistor on the electrical components.
By the very scientific "hand in front of the fan" test my fan seems to be blowing about 11.8% harder than my co-worker's which seems adequate to cool the computer.
That's a pretty accurate hand you have! My fans all blow somewhere around 50% more air than they need to. Heh.
Plopping a resistor on that bad boy shouldn't hurt it. It's a simple DC motor after all. It shouldn't affect anything else in the case.
Also, the only time you should have to worry about too much airflow preventing proper cooling would be if you were to build a wind tunnel out of your case. Current case and fan designs won't allow you to have too much airflow though. The trick is to keep the case's ambient air cool so that the processor, video card and hard drives have enough cool air to pull from to cool themselves.
Instead of hard wiring a resistor, may I suggest a prefab fan controller? You can get them for in-case, front bay or pci slot mount. It's not as haxor-ish of a solution, but it will certainly alleviate any fears you may have of cut-and-paste electronics solutions...
