07-02-2004, 09:14 PM
#1
Backup My PS2 Games
Hi Folks,
I got myself a dvd burner for my birthday and have started making backup copies of my movie collection. I am now considering buying some software to make backup copies of my wife's Playstation II games. Can anyone recommend a legally downloadable free or otherwise program that will do this with a minimal amount of labor? I'd rather make copies that don't need a "mod" chip in the PS2 to work.
Thanks in advance.
Peter
Stop Buying New Music CD's.
Hit The RIAA where it lives.
Indash Motorized 7", Epia Nehimiah, 512 MB, 80 GB, DVD, Wireless G, XP Pro, XM PCR, Kenwwod 5 Channel 1200 Watt Amp.
07-02-2004, 10:18 PM
#2
You can't. The PlayStation 2 will need either the MOD chip installed in order to play copied games, or the Flip Top mod. Flip top mods require you to replace the whole top of the PS2 and boot your PS2 with a bootdisk and then swap the bootdisk for the copied game.
As for as legality goes, well, it's supoused to be illigal even if they are your own copies of games you already own.
I have played on both types of Moded PS2's and I like the MOD chip much better, as you have to do the disk swap, which can get really fast.
As for backing up the games, easy task. Put the game inside your computer, the drive that will read the game, of course. Using just about any program out there, make an image file from the DVD-ROM game to your hard drive, such as *.ISO or many of the other popular formats. Once read and copied, it's as easy as placing in a blank DVD-R to your computers DVD burner and burn that saved burned image onto it from your hard drive. The reason I put the dash format (DVD-R) is that that is what I have used and it works just fine, I've read that the + (DVD+R) doesn't work, I really don't know.
OMG!!!!!  It's really that easy.
Reason: Too many mispellings.......
07-02-2004, 10:20 PM
#3
Other methods include loading them to hard disc, and throwing that in the PS2. Also requires some minor modification.
I'm very happy with my mod-chip, once done - no hassle
[Insert witty comment here]
07-02-2004, 10:28 PM
#4
Just noticed on Tech TV that there is no modding needed if you instal a standard IDE hard drive into your PS2 (must have the network card). You basically make an image on the HD of all your games. Just need a cd called HDloader to start the game. no swapping no modding
07-02-2004, 11:03 PM
#5
Why must I have the nic to install a hard drive?
07-03-2004, 01:13 AM
#6
I'm sorry, and you are....?
I assume you will have to copy the games over the network ?
[H]4 Life
I'm a lesbian too.
I am for hire!
07-03-2004, 01:16 AM
#7
or you could just buy a mod
knife trick works too (not really recommended though)
07-03-2004, 01:28 AM
#8
Not sure why, they said it was a must, even though you do not use any network features to do the trick. check it out....
http://www.hdloader.com/
07-03-2004, 01:47 AM
#9
I just read on a forum that the network adapter supplies the power connection for the HD.
[H]4 Life
I'm a lesbian too.
I am for hire!
07-03-2004, 03:38 AM
#10
Also supplies the data connection to the hard drive I think, I didn't see a standard ATA plug in there last time I opened it up
07-03-2004, 03:44 AM
#11
Just checked that site - I'd recommend that over a mod-chip.
Safer, no soldering, faster load times, cheaper (vs. good chip). Wish I'd seen this earlier now ...
07-03-2004, 10:15 AM
#12
Thanks Guys, I checked it out and seems the easiest way to go. Let's see what my wife wants to do. The NIC has a power port and IDE connector for the HDD. I guess there will be a boot disk involved also.
Peter
07-10-2004, 11:10 PM
#13
but you can't play/copy copied games onto the hard drvie unless you have a modchip installed already(you need it to load the games on the loader) I have it(hdloader w 120gig maxtor drive) and it's a monster, works everytime.
07-11-2004, 11:17 PM
#14
Really?
So if you copied them onto the hard drive via a computer, would HDLoader play them then? I don't see how HDLoader could tell the difference in that case, but you would have to unplug the hard drive everytime you wanted to load a game ...
If HDLoader STILL wouldn't play them for some reason - I'm once again content with just a mod-chip!
Thanks for the info Redmachine - I hope Chut sees this!
07-11-2004, 11:36 PM
#15
You could backup original games with it, or use a mod chip (flip-lid, or most methods) to backup backups. You could also just do the knife trick with that (to backup backups). The knife trick would be ok because you only have to do it 1 time to backup the game, not everytime you play it.
At least that's what i got from cdrom-guide.com. I don't own this and have not tried it.
| Thread Tools |
| Display Modes |
Linear Mode
