Quote: Originally Posted by Scouse Monkey
if you fit a more powerful engine... it is also likely you would have to increase the power of your tail rotor to maintain good control due to the increased thrust and therefore torque of the main rotor.
Good point
If you double the wing (blade) area, you (slightly less than) double the lift. This is only true if the rotational speed of stem is kept the same. Most likely you would need a stronger motor to keep the same rotation speed because of the increase in mass it's trying to rotate.
Simply adding more mass to the stem, spinning, means you'll have more rotational inertia that the tail rotor will need to overcome.
I've never built an RC helicopter, but you do have other options, I just don't know how doable they are.
1) Make the blades longer... more surface area=more lift... however it means more mass so you'd need a stronger motor.
2) Add aditional blades on the same plane... 4 instead of 3 or 5 instead of 4... more surface area=more lift... however it means more mass so you'd need a stronger motor.
3) Add an independent second motor and set of baldes... a la Chinnook . If you could regulate them some how to keep them rotating at the same speed, then you would have no net inertia causing rotation. Add a tail rotor and you could control rotation. And you would have one mean looking beast of a toy.
