Not sure if you're aware of this, but fuel tanks are designed with a certain amount of reserve, so that could account for your gauge being accurate.
Also, fuel gauges purposely lie. They are full, that is pretty much correct, but if you've ever noticed how the gauge will stay at full for a long time, then start to go down, then when you get near empty the gauge seems to rush towards "E"? That's purposely built into fuel gauges. This is done to 'trick' the driver into thinking they're about to run out of fuel any minute and should refuel soon.
Cadillac had a car in the 80s that had a digital read-out that showed the number of gallons in the tank. The problem was that it showed the accurate number. People started complaining about poor fuel economy because it wouldn't stay full very long.
BTW,fuel senders in the tank tend to go on the expensive side. And yes, you're right. It is based off of a resistance, between 70 an 90 ohms for GMs.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
