Go Back   MP3Car.com > General > Off Topic
Old 04-05-2005, 10:57 PM   #1
Top Ramen
lgbr's Avatar
lgbr has a little shameless behaviour in the past
My New Toy (56k prepare to die)
Well, it runs like ****, but it's awesome.
Was driving it home, and I'd be suprised if I was putting 70 to the wheels. It was running like crap. Later, I bleed and filled the coolant, and put a little extra oil in. Ran pretty damn fast. Turbo doesn't help much yet. Oil pressure light comes on under 2,000 RPMs. Took the t-top off and went for a drive, I got cold but i didn't care.
Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
Head units are for cheaters!
Quote:
sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
lgbr is offline   Reply With Quote
Old 04-05-2005, 11:20 PM   #2
Raw Wave
BoyNextDoor's Avatar
BoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud of
if you want some advie on how to get this car together so it will run a lot better, pm me. i can give you ton's of advice. Nice ride BTW: how much did you buy it for? I might consider a car like that for my wife...
let me know...
BoyNextDoor is offline   Reply With Quote
Old 04-05-2005, 11:22 PM   #3
Top Ramen
lgbr's Avatar
The car was $2,700. If the car was in better condition it would go for over $5,000. What's this advice you have?
Old 04-05-2005, 11:56 PM   #4
Raw Wave
use the auto-rx treatment on your engine
www.auto-rx.com
than use about two big bottles of LUCAS FUEL INJECTION CLEANER (one bottle is enough for 4 tanks of gas (8 ounces each gastank) you can buy them at the local car parts store. I used to do it like this. before you fill up your car, pour 8 ounces into the tank. use this at every fill-up you make for at lease the first 8 fill-ups and after that at least every 3-4 fill-ups get 8 ounces of it in there. This helped me keep my caravan alive, and also helped me regulate the rpm on my passat.
Clean the **** out of it. what i did when i got the passat was:
I removed the seats. deepcleaned the carpeting and upholstry. rented a carpet cleaning machine for that. this is for two reasons. one beeing thet you want a nice clean car, now don't you... the other beeing, probably the car has not been cleaned like that before. even if it looks nice, it could be bad. like you never know who owned it, and all kinds of bacteria and a lot of disgusting things could be in the upholstry, and carpeting. so it's healthy to clean the car out deeply. i also deepcleaned the seats. I also used some of my wifes dishwashing solution (in this case Palmolive) to scrub the plastic parts/dash/steeringwheel. you wouldn't believ what the machine, and the sopay water looked liek after the cleaning. so at this stage you have a clean car. If you are lucky like i was, you gonna smell the factory scent of the car after a couple of days. now you should apply some armor all (also found at local parts stores) to the plastic parts. all of them. you better do this until you still have the seats out, so you can reach all the parts of the car. oh. and when deepcleaning, don't forget about your headliner. i almost forgot about it.
as for extrior, get a good thurow wash, rather was by hand with a car-washing brush (walmart $2.50) and clean water. no shampoo is the best or only use good quality shampoo. if you want to go all the way, (i stil have to do this) polish the car. don't wax it, polish it. i use mothers 3 step system. three different polishes.
1. cleaner: cleans all the old waxes, polishes, tar and road debries off of your car.
2. Polisher: it polishes the **** out of your car. By this time you would blind yourself if you look into the polished areas. it's that good.
3. sealer: as it sas. seals the new polish and protects it. (all three cost like $9)
now all the three steps only have to be done once or maybe twice a year. after this you would need to re polish and seal it about every 3-4 months.
some tips with polishing: only polish above 65F outside, because under that you would harm the clearcoat. also only polish in shade. you can screw up the paint if you polish in sunlight.
Next: have the engine shampood. you better go to a professional shop and let them do it, it's about $60-$65 and you would do it once a year. so it's grease free and nice looking.
check and replace all of the fluids. you already replaced the coolant which is good, but you also should flush it. it gets all the louse debrees in the system out. to flush it it's about $20 at the local shop plus the fluid. flush the power steering, and brake systems too. it's not a life-death necesity to do these but it gives a trumendous amount of peace of mind tat you have a clean car. if you can, change to synthetic oil. it's more expensive but it's worth it. let the local shop check the turbo out. you may have leaks that prevent it from functioning properly. and again auto-rx the engine. you can find more info on the link above. i'll post a link later from someone that tried it, and documented the effects. check all the rubber seals arount the trunk lid(s) doors.
Oh boy i think i crapped a post like an elephant. this is what i would do to a car when i buy it. even if it's newer. i will continue doing all of that on my car too. with time though. o one more thing. check the brakes, and if necessery (or maybe even if not) change the rotors and pads. you gotta stop after going fast.
sorry for the huge amount of info here. hope it helps. i still come up with new and new ideas but this post is already way too long. I may do a sticky thread on how to keep the car healthy.
cheers
Old 04-05-2005, 11:58 PM   #5
Raw Wave
oh boy i got scared when i saw how long the post is
Old 04-06-2005, 02:51 AM   #6
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
Congrats on your new purchase! Its an awesome projectcar Good luck trying to drive 2 of your mates around
0l33l is offline   Reply With Quote
Old 04-06-2005, 03:28 AM   #7
It ain't easy being a green moderator
meddler's Avatar
Location: Steps out the front of Henson's workshop or Sydney
meddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud ofmeddler has much to be proud of
looks like it needs a carputer badly
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
meddler is offline   Reply With Quote
Old 04-06-2005, 04:44 AM   #8
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
Looks like it needs a good clean and respray!
Cool car though, been having the odd sly look for one ont he side and for $2700 you can afford to do a lot of stuff to it. As long as the engine is sound that is all that matters - everything else can be sorted with a little time and TLC.
and yeah, carPCs go very well into MR2s - lucky bastard!
nice one lgbr, shoudl work out pretty cool - but i was right - MR2!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 04-06-2005, 05:08 AM   #9
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Nice double DIN for a 7" LCD or maybe an 8".
Enforcer is online now   Reply With Quote
Old 04-06-2005, 06:21 AM   #10
silencery's Avatar
silencery is on a distinguished road
sweet! gotta love MR2s All gens even...
Toyota's notorious for having fading red paint... it's gonna take a lot of work for that finish. As long as its running though, it's all good
Make sure you take the time to learn how to drive it properly. Mid-engines need some extra attention. They'll treat you very well though and take you through the turns like no other...
Congrats!
EDIT: *****!! just noticed it was a turbo. OMG@!@! You got a good price on that car man... highly sought after. Here in so cal, a good condition '93 TT Mk2 will go for almost 9K!@!! If you can fix it up, it'll be a beauty. Really gotta say.. i think i'd be as excited as you if I were buying it... haha.
Stealth OEM spyder
1204 dot net!
silencery is offline   Reply With Quote
Old 04-06-2005, 08:17 AM   #11
MySQL Error
All red paint fades worse than any other colour. The only car paint that won't was too dangerous to use (in the old days anyway).
If you get the red brightened up it will go faster
Old 04-06-2005, 08:24 AM   #12
Confusion Master
Enforcer's Avatar
Yeah, loads of polish, it will reduce the drag factor
Old 04-06-2005, 10:16 AM   #13
Bowel movement
jjh221's Avatar
jjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud ofjjh221 has much to be proud of
MR'2... MR not... O S A R!... C M wings?... Well I B, MR2's
cool car
I GIVE FREE HUGS!
Buy Sell or Trade
If my pm box is full, please feel free to call me any time. 440-328-3382
Thank you
Forex
Rate Mp3car @ FXroot.com
jjh221 is offline   Reply With Quote
Old 04-06-2005, 10:18 AM   #14
Raw Wave
what do you guys think? should i make a stiky on how to keep you're car healathy?
Old 04-06-2005, 05:24 PM   #15
Raw Wave
i see you went right at it.
cheers
Cool new toy I got (USB enclosure for slim DVD/CD drive) SFiorito General Hardware Discussion 15 02-23-2005 12:27 PM
Look at my new toy . allenruble Off Topic 6 05-12-2004 04:33 PM
My new toy.... outragis General Hardware Discussion 11 03-13-2004 07:25 PM
Look at my new toy. allenruble LCD/Display 23 06-02-2003 06:55 PM
New Toy ! Rob Off Topic 8 08-20-2002 02:02 PM
