04-06-2005, 06:35 PM
#1
MySQL Error
Removing glue from dash
Well as most of you know I took the aftermarket dash kit off of my car, which went really well with the exception of screwing up 2 peices which only come to a total of $50 from the volvo dealer.
but now in some places some of the glue from the double sided sticky tape is still stuck the dash
anyone know of anything that will safely take that glue off? I dont want to use something like goo gone or goof off because I know it will ruin the dash. (I tested it on a old piece of dash that I had and it turned it into putty)
any ideas?
04-06-2005, 06:42 PM
#2
Raw Wave
I had the same problem. I used some mineral spirits but still needed to paint it as it was discolored, if your a masochist, you could use this for the motivation to paint your dash.
Bit of a PITA. This was before I had a spare one. I ended up doing it several times trying to get it flawless. I was driving around with my gauges wiretired to the cross support for months and an afghan, covering the mess.
Finallly I said good enough and put it back in.
04-06-2005, 06:43 PM
#3
MySQL Error
ouch, yeah I was trying to get around repainting all the parts
04-06-2005, 06:51 PM
#4
Raw Wave
Maybe dampen it with a sponge and some soapy water, then a hair dryer to heat and loosen it?
Actually, when I first botched my trim kit, I tried peanut butter. I've read this a bunch of places. It worked ok, but not good enough. I will advise against alchohol. The seller told me I should use it to prep my dash. My floor console got dull and soft. I could run my nail through it and leave a mark. It did firm up again but the finish was ruined. Sort of started me down the whole long painting road.
04-06-2005, 06:58 PM
#5
MySQL Error
yeah I think I am going to try some soapy water and see if that helps, i'm lucky most of the glue came off, so it's only in a few spots
04-06-2005, 07:03 PM
#6
Bowel movement
i dont see why mineral spirits wont work i use that on everything and goo gone or goof off i think its called
04-06-2005, 07:04 PM
#7
MySQL Error
use some of that orange spray - it is very good for getting glue off. Or just save money and use some citric acid from a couple of oranges! That is all it is. Jsut test it somehwere 1st (see how it dries especially). But 1st try soapy water.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
04-06-2005, 07:40 PM
#8
MySQL Error
04-06-2005, 07:42 PM
#9
MySQL Error
yeah I will try that
04-06-2005, 10:23 PM
#10
Bowel movement
lol ok kick me i was lazy
04-06-2005, 10:25 PM
#11
Bowel movement
what about break cleaner?
always clean any stuff left over off.
04-06-2005, 10:30 PM
#12
MySQL Error
actuall i've been working at it with the cleaning wipes from amorall, and its working pretty good just going to take a little while
04-07-2005, 12:02 AM
#13
Bowel movement
good im glad to hear it. Sorry i didnt read.
04-07-2005, 04:16 AM
#14
Unregistered User
Wd-40?
ODYSSEY
Quote: Originally Posted by Tidder
All information expressed in this post is my opinion, and should not be regarded as a statement of fact. Digital-Car UK|
(\__/)
(")_(")
04-07-2005, 04:31 AM
#15
MySQL Error
Quote: Originally Posted by ODYSSEY
Wd-40?
oh nooooooooooooooo! it will go all shiny and you will never get the oil off the plastic unless you use brake cleaner and that will most like damage the plastic finish
| Thread Tools |
| Display Modes |
Linear Mode
