USB Hdd cannot be seen
Well this is not really off topic, just wasn't sure where to post it so here is the problem:
I have a Vaio notebook (grx670) where i have all my music. to transfer music, pics, progs from the laptop to my caprpc i want to use a usb/firewire hdd like the ones that come in a hard case (removable ones). Problem is i cannot do that cause every time i connect it to either firewire or usb it will work for a few seconds then the pc will freeze and after a while it will work again but the usb drive will not be in thedrive list. If i go to control panel /system/devices, i can see it there with a warningthat there is a problem with it.
I searched on google and found out there is an incopatibility with SP2 (which i have) and firewire/usb and i should try putting the SP1 sys files. Tried that, it worked for a session and now i have exactly the same problems as described above. anybody has any suggestions /experiences with this matter? It is not the drive enclosure cause it works fine on every other pc! and i am sure it is not the pc cause it used to work before SP2!
-VIA EPIA M10000/512MB/40GB HD
-DWW motorized 7'
-BU 303 GPS w/iGuidance/ CF
-Opus90w
-Belkin Bluetooth
-Pioneer HU
[||||||||||] 95% done
