Go Back   MP3Car.com > General > Off Topic
Old 07-17-2005, 12:12 PM   #1
Jay2001's Avatar
Jay2001 is on a distinguished road
HELP! - Jeep Cherokee Alarm Fault
Hi all,
Car: 1998 Jeep Grand Cherokee Orvis (UK)
I have gone out to my car this after noon and the key fob has no effect on the car. When I press the unlock button my Jeep remains unaffected. The car next to mine bleeps and flashes it's indicators suggesting some interference but it doesn't unlock it.
I have been out and purchased a new pair of batteries for the key fob, same result.
I have tried the new batteries in the second key fob, same result.
The car worked fine this morning at about 11am and this problem was noticed at about 4pm so something has gone wrong in those 5 hours.
There is nothing in the car that could have drained the battery.
If I unlock the door with the key the central locking doesn't work but I don't know if this is usual behavior as I have never used the key in the door before! It also doesn't unset the alarm or the imobiliser so when I open the now unlocked door the alarm goes off. Having closed the door the alarm resets after about 10-15 seconds.
Anyone any idea what could be causing this, and more importantly, how to fix it before work tomorrow?
Jay2001 is offline   Reply With Quote
Old 07-17-2005, 04:33 PM   #2
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
0l33l is offline   Reply With Quote
Old 07-17-2005, 04:37 PM   #3
marshallh's Avatar
marshallh is on a distinguished road
Maybe your solenoids are shot, or the fuse for that was blown? My sister had the exact same problem with her Civic.
Progress:
[■■■■■■■■] 100%
Mitsubishi 3000GT car computer
Previous budget Honda carputer
marshallh is offline   Reply With Quote
Old 07-18-2005, 05:59 AM   #4
Jay2001's Avatar
I am currently suspecting the sensor as I wouldn't have thought a single solenoid or fuse would take out alarm/imobiliser/central locking all at the same time...
Old 07-19-2005, 08:16 AM   #5
Jay2001's Avatar
OK, well apparently the Alarm just needed resetting. Do any Jeep owners here know if there is a way to deactivate the security system without the keyfob?
I am wondering what you would do if you were out in the middle of nowhere and the batteries went flat...
On my rover you could enter a code using the key in the drivers door lock for example.
Any one know?
Old 07-19-2005, 04:47 PM   #6
binary.h4x's Avatar
binary.h4x
why not just disconnect the battery and then reconnect it?
binary.h4x is offline   Reply With Quote
Old 07-24-2005, 07:18 AM   #7
Jay2001's Avatar
That doesn't reset the alarm.
Old 07-24-2005, 07:50 AM   #8
muldrick's Avatar
muldrick is on a distinguished road
Use the key to lock/unlock the RF door. If it doesn't reset (alarm turns off), there's a problem with that door lock cylinder (or actually a switch on the back of it)
If it doesn't reset, try the LF door. Either door should reset it.
EDIT: you're UK....I switched the doors above
AtmosUSA.biz, E-Cig Mods
muldrick is offline   Reply With Quote
Old 07-24-2005, 02:05 PM   #9
Jay2001's Avatar
Sorry, you misunderstand. The Alarm had gone into a "Fail Safe" mode and could not be "reset" without the aid of a compenent auto-electrician. Nothing wrong with the keys, the door lock cylinders, or the key fob transmitter.
Once in this mode unlocking either door with the key will allow that door to be opened but will not unset the alarm, the imobiliser, or pop the central locking.
Thanks for trying though.
Old 07-24-2005, 09:37 PM   #10
muldrick's Avatar
Got ya'.
That's messed up...what caused it? Hate to see this happen on a trip to BFE.
I used to work on these and I remember if the wrong key was used, the car would crank and start, but then stall. After a couple of tries the starter would "deactivate". I remember once the starter quit, the customer would be screwed and need dealer service. Is this what happened?
Still seems like you had a component failure or glits, if it wouldn't start to begin with.
Old 10-13-2005, 06:04 PM   #11
Jay2001's Avatar
Sorry, wasn't checking this thread any more.
I have no idea what caused it, dealers were as stumped as I was. There was no component failure and nothing needed replacing it just needed a reset. I spoke to Jeep about this and they said there is nothing you can do in this situation. I asked them what I would do if this happened in the middle of nowhere and they said "get the car recovered to a dealer". Thanks, that heps a lot!
83 Jeep Cherokee Hellcat Show off your project 4 07-22-2009 12:52 PM
jeep grand cherokee install jackjohnson24 Newbie 1 01-12-2005 02:53 PM
anyone know how many DIN a 1998 jeep grand cherokee laredo is? Nav_Attack General MP3Car Discussion 2 09-08-2004 07:12 PM
2000 Jeep Grand Cherokee jmhenry5150 Show off your project 0 10-15-2002 10:16 AM
Jeep Cherokee mnbujold Off Topic 4 03-07-2002 07:17 PM
