Go Back   MP3Car.com > General > Off Topic
Old 07-23-2005, 07:17 PM   #1
Psychobiker's Avatar
Psychobiker is on a distinguished road
Rained on my frickin' motor!
Hi,
My electric window motor has been recently subject to a little h2o...window seal gone. I am wondering, since the motor hasn't actually burnt out or short circuited,that when it dries out it will work? Will it?
1996 Volvo 850 T5 CD - Eventually I'll start....
Psychobiker is offline   Reply With Quote
Old 07-23-2005, 07:25 PM   #2
I need to know ASAP please
L
Old 07-23-2005, 07:30 PM   #3
Poet Laureate
rustyboxx's Avatar
Location: The Côte d'Azur of England - Hot totty central
rustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud ofrustyboxx has much to be proud of
I don't see any reason why it shouldn't provided that there was no current to it when it was wet. IMHO and occasional experience it should be okay if you make sure all the moisture is dried out thoroughly before you allow power to it.
Only true postwhores remember everything they post
REP CLUB IS DEAD
LONG LIVE REP CLUB
rustyboxx is offline   Reply With Quote
Old 07-23-2005, 08:07 PM   #4
Super Moderator
xBrady's Avatar
xBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to beholdxBrady is a splendid one to behold
It should be just fine. I've got a motor for something else wet and after I let it dry out for a day it worked.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 07-23-2005, 08:49 PM   #5
Raw Wave
Chris31 will become famous soon enough
Make sure you check the motor bearing/gear/mechanism for trace of rust...whatever you can see that might cause problems later. Just reoil/grease it.
Chris31 is offline   Reply With Quote
Old 07-23-2005, 08:53 PM   #6
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
L
crikey! 8 minutes and then posting again!
Jsut dont be so impatient with the motor. Give it a good couple of days to dry out and it should be fine. Its just like when you spill something on a remote control - let it fry for a few days and it willbe fine.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 07-23-2005, 10:51 PM   #7
Stealth97 is on a distinguished road
IVe had whole computers submerged before. Just let it dry, and it will be no prob.
Is this where the witty comment goes?
97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
Stealth97 is offline   Reply With Quote
Old 07-23-2005, 11:24 PM   #8
PatO's Avatar
PatO is on a distinguished road
THREADJACK! (But slightly on topic)
Diagnose this: Window doesn't roll down. But lights on the drivers switches dim (like normal) when that window is toggled. What's wrong?
The dimming would imply that the motor is getting juice & the circuit is intact. That is assuming that the motor is wired through the switch - if it isn't, why would the lights dim? So, what can go bad with auto windows? Is it most often the motor, or do parts commonly rust/freeze?
What should I expect before I crack the door open?
http://www.jeepmp3.com/
CarPC Stolen. Starting over.
Ne1 recognize the avatar?
PatO is offline   Reply With Quote
Old 07-23-2005, 11:39 PM   #9
Raw Wave
wizardPC's Avatar
wizardPC will become famous soon enough
PatO:
most often the motor has siezed. After that, the scissors that move the window up and down.
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 07-23-2005, 11:59 PM   #10
Zac
Zac is on a distinguished road
and the lights dimming would follow that same idea - the motor is soaking up much more current trying as hard as it can to move.
Zac is offline   Reply With Quote
Old 07-24-2005, 12:47 AM   #11
PatO's Avatar
Gotcha. Thanks Wizard and Zac. That seems to make sense.
Off to the junkyards!!!! (I hope no one runs into me on the way home...)
Old 07-24-2005, 01:13 AM   #12
Underachiever
ACHIEVER's Avatar
Location: Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
ACHIEVER is on a distinguished road
Pat, I had the same thing happen on a car a couple years ago. The motor gets seized up as already mentioned. Sometimes/usually when this happens the motor is dying. But I was able to give it a little more "juice" by hooking a battery charger up straight to the window motor, bypassing everthing including the switch. Also you can try tapping on it with a hammer or something while powering it. My window still works fine to this day. Give it a try to save some work and money.
ACHIEVER is offline   Reply With Quote
Old 07-24-2005, 02:31 AM   #13
PatO's Avatar
Ha Ha! I use to do stuff like that with old Rock Tumbler motors (Boy Scouts). Soaking them in oil for a few months sometimes did the trick, too.
I liked your last girl better...
Old 07-26-2005, 08:38 PM   #14
Underachiever
ACHIEVER's Avatar
Had any time to work on your window PatO? Curious what you ended up doing.
Old 07-26-2005, 09:04 PM   #15
Sorry, it eventually turned out I hadn't earthed the auto-down relay and it refused to do anything. Also let it dry out, working no prob!
Sorry for my impatience
L
Headlight motor to raise screen lostreception General Hardware Discussion 28 07-07-2005 05:46 PM
IGN controlled motor lostreception General Hardware Discussion 4 07-03-2005 12:25 PM
Smallest Motor alienjj Hardware Development 6 05-09-2005 07:41 PM
reversable motor for monitor? more mods General Hardware Discussion 202 12-12-2004 05:20 AM
Can I power a LaserDisc motor with the OPUS 150w? afr0puff Power Supplies 1 02-27-2004 09:28 PM
