I almost agree with your friend, but it wouldn't be the "inside/outside" door.
There are several doors, 1. the "inside/outside" or what I call the recirculation door, 2. the "mode" door, it controls the mode ie:defrost/vent/floor, 3. the temp door: it controls hot/cold.
Each of these doors have a "changeover damper motor", or a servo motor.
Problem? Either there is an issue with the temp door, the linkage, or the motor itself.
Diagnosis? Crawl uder the dash when it makes the noise...find out which motor/door it is coming from, take the motor off and see if the door and linkage moves freely. If it does than it is most likely a bad motor.
It may be tough getting to the motor...but you CAN do it
Quote: Originally Posted by Cheekz185
OK....Here we go. Lets start off with>> I have a 2002 Mitsubishi Galant 2.4L
In late January I was having problems with my heat! Whenever I would turn the AC knob from Cold --> Hot / Hot ---> Cold there would be this rattling noise for like 5 seconds under my dashboard in the middle. It would be a fast rattle. As time progressed It would do it every so often and everything was fine. But it started up again around March. But every time it would rattle my heat would not work. It would blow just cold air (No warm air what so ever!).
Next, The heat would not work for a couple days straight (with no rattle when switching temps), then all of a sudden it would rattle again, then the heat would work. So that was happening for a while. But now it doesnt rattle anymore and there is no heat AT ALL. A friend of mine said it mite be the "Inside/Outside changeover damper motor" He said it is like a "DOOR" that mixes the hot and cold.
I would just like to hear some of your input guys! If you can help me out that would be great!
