07-28-2005, 10:03 PM
#1
HELP!! My Cig Lighter Does Not Work!
OK so I bought a 140W AC-DC cigarette lighter adapter from RadioShack. I was going to use it to plug in my laptop. So I hooked everything up and i started driving and after 10 min the adapter stopped charging my laptop. There is a little green light on the AC-DC adapter and when it is getting power it lights up so after 10 minutes that light went out. SO i was like OK thats really weird. SO the DUMBASS that i am i decided to plug it into the bottom cig lighter (cuz there are 2 one for the cig lighter and another for whatever) and after a half hour it did the same thing!. I tried pluging other things into the cig lighter and nothing. Doesnt heat up the cig lighter.
SO here is what i did....I checked the fuses in the fuse panel and they are all good! Every one it still working. I checked them all. I also checked under my hood and found nothing.
What can i do to fix this?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
07-28-2005, 10:18 PM
#2
Try it in a different car and see if you have the same results. If not, the problem is in your car. If the problem still happens, there is a problem with the inverter.
Batman
Batman@TheNewBatcave.com
AMD XP 2000, 1gig PC2700, 80gig 7200RPM HD, DVD CD/RW, ATI All in Wonder 8500DV w/remote, DataChute, IRDA, Wireless 802.11b, cell modem, Lilliput 7" VGA TS, XP Pro, GPS w/Routis
www.samshomepage.net
www.Cars-N-Computers.com
07-28-2005, 10:20 PM
#3
It is my car, cuz nothing works when i plug anything into my cig lighter, not the inverter. Inverter doesnt even power any more. I just tried changing the fuses but nothing....
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 10:41 PM
#4
Calm Down Or Get A 2 Week Vacation -Love The Forum Policeman
Hope you didn't burn up any fusible links. You should check to see if your car has them.
Michael
07-28-2005, 10:43 PM
#5
Bowel movement
have you tried turning the key?
dont know much about them but if were me id take it out of your dash or where ever and have a look see and maybe buy a new one?
Michael
oh yeah inline fuses? is that what ya mean. I never thought of that.
Just take the car back, say its defective.
holly blasting caps batman, your back!
Ok im off to bed
night
07-28-2005, 10:45 PM
#6
Michael
What are fusible links, and where would they be
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 10:59 PM
#7
an inline fuse holder?
could look like this?
https://secure1.nexternal.com/ae/images/90-811.jpg
just follow the wire that the powers the cigarette lighter socket
I'mmmmmm a n00b.... feel free to make fun
07-28-2005, 11:05 PM
#8
Takes it in the Rear
12 amps on a Im guessing 10 amps cigarette lighter = blown fuse.
Check the fuse box and see if the fuse is burnt. Next time hardwire it to the battery.
#9
Quote: Originally Posted by markopolo311
But why would there be 2 fuses on the same line?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 11:09 PM
#10
it is a 15amp line
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 11:15 PM
#11
dude if you have poped a fuse in your vehice fuse box, don't be so quick to replace it. Your cig adaptor might have a fuse in it as well. Think of it as protection. Why not 2.
so if you replace both lets say, still got to figure out why they blew.
My guess is you have too many watts/amps being drawn and that may have blown the fuse. Don't put a bigger fuse in. The wire connected to your cig lighteer in your car may not be able to handle the watts/amps and overheat/melt/catch fire.
You should consider running a dedicated/ thicker awg (gage) wire for your inverter.
How many watts is your inverter (peak)??
03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
Carputer Planning |---------*|
Overall Implementation |---------*-|
(Stereo complete)
Computer installed and working
07-28-2005, 11:18 PM
#12
So your saying that there should be another fuse? And that is prolly the fuse that blew? How would i find out if there is another fuse? I gotta follow the wire i guess....
Here is the inverter:
http://www.radioshack.com/product.as...ct%5Fid=22-148
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-28-2005, 11:25 PM
#13
ok look at his link
http://www.electerm.com/gfx/fusegfx/cig-m.jpg
this one will more than likely twist off at the end. if you unscrew it, you will probably find a fuse in there. Your inverter sounds like it's ok, but my guess still is that it is pulling too much wattage/amps.
Your inverter is good for 20 amps. thats all it will provide. tops
most cig adaptors (not all) will carry a lod of 5 to 10 amps.
If each cig adapter in your car have a fuse, then that explains why blew and the other worked for a short time.
It could also be a protective circuit in the inverter. hard to say.
What are you connecting to the inverter?
(Stereo complete)
07-28-2005, 11:37 PM
#14
it's not the fuse in the tip of his inverter plug b/c the cigarette lighter doesn't heat up anymore
07-28-2005, 11:39 PM
#15
the device that made it heatup was the device you would light your cig with, not the socket.
what do you pluginto your inverter?
(Stereo complete)
| Thread Tools |
| Display Modes |
Linear Mode
