Go Back   MP3Car.com > General > Off Topic
Old 09-14-2005, 06:12 AM   #1
Vchat20's Avatar
Vchat20 is on a distinguished road
inexpensive rust repair?
very simple: anyone know of an inexpensive method to repair rust? specifically on the roof of a car if it helps any.
reason i ask is because our van has recently developed this nice rust spot on the roof right smack dab in the center. the paint has done chipped away and the bare grey metal underneath has started to rust away. since we dont want to have a waterfall in the back seat and cant really afford to take it to a professional body shop, does anyone have an inexpensive "DIY" fix? ive always thought that the simple yet effective route was to simply sand the rust off and get back down to the clean metal, reprime and paint. but being as car illiterate as i am, im not so sure if this is a good solution. and considering the rust's location, i cant take chances.
and for those who cant read, im NOT looking for "take it to a body shop".
Your everyday carpc geek and tech guru at your service. *bow*
Vchat20 is offline   Reply With Quote
Old 09-14-2005, 06:24 AM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Convert van to a convertible.
Enforcer is offline   Reply With Quote
Old 09-14-2005, 09:20 AM   #3
KB5WID's Avatar
KB5WID is on a distinguished road
http://www.therustdoctor.com/
If It's Called Tourist Season, Why Can't We Hunt Them?
I Just Do What the Voices Inside My Head Tell Me to Do.
The Definition of an Upgrade: Take old bugs out, put new ones in.
Texas DOS: Y'all reckon? (Yep/Nope)
KB5WID is offline   Reply With Quote
Old 09-14-2005, 11:54 AM   #4
Takes it in the Rear
kevinlekiller's Avatar
kevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud ofkevinlekiller has much to be proud of
This is if you want to repaint the roof, this is how I do it, its cheap because I own the stuff already, I dont know how much these things can cost you. I dont go much into detail, I think you can figure some stuff yourself .
You need to grind, sand blast, than you sand down with a air sander (220) taking off the paint till your at the primer (or the paint will chip when afterwards) wash with some kind of acid (dont remember the name ; ask local car paint shop ; its greenish blue) , prime as soon as your done. If you cant prime as soon as your done Its going to start to rust after a few hours, and places were you grinded will be a ***** , because grinding makes little potholes when your a newbie(no offense) and than you need to resandblast. The rust is easy to come off (except for grindings) , you just pass back with the air sander, and clean with the acid.
If you see spots that the rust is eating through the roof (holes) grind it down , and get some fiberglass. Than you grind down the fiberglass grind that too , and apply metal filler. Than you sand the metal filler with the air sander (wear a mask) or sandpaper.
You can use sandpaper and a block instead of a airsander, but your hands will cry after a while; lol.
A grinder is a must , I recomend a air one, electrics are cheap as ****(cant control speed; are freakin heavy). Get a electric if you dont have a compressor.
kevinlekiller is offline   Reply With Quote
Old 09-14-2005, 12:11 PM   #5
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
http://www.rustbullet.com
tj!2k4 is offline   Reply With Quote
Old 09-14-2005, 07:12 PM   #6
BassBinDevil's Avatar
BassBinDevil is on a distinguished road
Sand(blast) or wirebrush off the surface rust, then apply Naval Jelly or the equivalent (it'll contain phosphoric acid)(Ospho or Metal-prep are similar things in more liquid form). Brush with someone else's toothbrush to work it into the pits and keep fresh acid in contact with the rust; let it sit for a while to work. Wash off the residue, wipe with thinners or alcohol or other solvents of choice. Fill the pits with marine grade Bondo (it's supposed to be more waterproof than regular stuff), or whatever epoxy glue you have lying around. Sand flat, prime, sand some more, and then paint.
BassBinDevil is offline   Reply With Quote
Old 09-14-2005, 10:29 PM   #7
HHdesign's Avatar
HHdesign is a jewel in the roughHHdesign is a jewel in the roughHHdesign is a jewel in the rough
Hit it on the head. I have 3 hours of auto body class each day, and today I fixed a softball sized rust hole in the door of a retro mustang. We use air powered everything. Grind it down, get all the rust. In my case I'm going to have to do some welding to fix the giant hole now, but you should be ok with glassing it. Get a Dual Action sander, You'll find its extremly useful, even outside the shop.
Jeep Grand Cherokee Laredo
Kenwood X790 x/ iP500 Ipod Interface
Elemental Designs 13Kv.2 D2
CDT ES-620 (omg yayay!!!1)
NINe.2X, NINe.2
HHdesign is offline   Reply With Quote
Old 09-14-2005, 10:42 PM   #8
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
if your just looking to prevent it from getting worse & aren't to concerned about the repainting of the roof, I would suggest you wirebrush or sand it a little, then coat the spot with por-15...when that dries in a day or so just touch up the spot..... DONE, no grinding or glassing, por-15 is awsome stuff for rust stoppage.... it is available in small quantity.... there based in NJ.... I use it in my bodyshop & I've used many other so called rust stoppers, this is the best...just don't get it on your hands or it'll be there for a few weeks
turbocad6 is offline   Reply With Quote
Old 09-14-2005, 11:27 PM   #9
I never use electric , air is the way to go , with electric theres just 1 speed setting.
PCB Repair xhazn General Hardware Discussion 16 04-24-2005 03:47 PM
Inexpensive DC-DC power supply for 12V only? P4_2.66GHz Power Supplies 10 11-20-2004 10:17 PM
Inexpensive OBD-II reader and software philstuf Engine Management, OBD-II, Engine Diagnostics, etc. 0 07-03-2004 07:19 PM
Car Paint Repair Question Max018 Off Topic 4 03-12-2004 01:03 PM
touchscreen overlay repair? Jarrod Input Devices 3 01-29-2003 02:41 PM
