Go Back   MP3Car.com > General > Off Topic
Old 09-21-2005, 12:23 AM   #1
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
Help, scary lights...Accord Owners/ Mechanics please help
Two days ago I installed the carnetix 5v POL in my car in the center console. This is right where the parking break cable runs through. (additional info....it is being powered by a fused distrobution block with the PC in the back..... its a 10 guage wire running up from the trunk...the computer is operating normally, and the POL is operating normally as well.)
I'm not sure if this is related, but today I had 3 lights come on in my dash.
Interestingly....these were not "check engine" or "service engine".
They were, the battery light, the parking break light, and the "break lamp" light.
I checked to make sure my break lights were working, and they were, no problem.
Is there some kinda sensor right there in the center console that I could have shorted?
please help
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 09-21-2005, 12:47 AM   #2
ATXaccord05's Avatar
ATXaccord05 is on a distinguished road
did you tap a wire in there? I think you said you got it elsewhere, but maybe i'm wrong. also check your battery voltage, and if it's not that, it might just go away by itself.
ATXaccord05 is offline   Reply With Quote
Old 09-21-2005, 01:30 AM   #3
Peoples's Avatar
The power is comming straight from the battery which is how its been going since easter. i didnt intentionally play with any wires in there at all. I'm thinking if i reset the ecu it should go away.
PC Components:
My work log
Old 09-21-2005, 01:42 AM   #4
Banned
xdjxklusivex's Avatar
xdjxklusivex will become famous soon enough
yo just take it to the honda dealer they will diagnose it for u or just unplug ur battery for a few minz then plug it back in and see if it goes away
xdjxklusivex is offline   Reply With Quote
Old 09-21-2005, 01:42 AM   #5
when I put TYC's into my car my brake lamp came on, then went off right afterwards.
Old 09-21-2005, 02:18 AM   #6
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
If those 3 lights come on at once on my Supra, I know that the alternator is on it way to heaven.
With the engine running, use a meter to check if the alternator put out at least 13.5+ volts.
Now turn on all electrical equipment you have in the car to see the light get dimmer (also step on the brake). Now if the engine still running without hiscup (sp?), the alternator is probably okay. The point is to see if the alternator push out enough juice to power all those electrical component.
Another quick way (but dirty) is to remove the POS (+) terminal of the battery to see if it is still running. You have to be carefull on this test. I use this all the time. If the engine shut off after you disconnect the terminal, I am sure the alternator is 3/4 way to heaven already.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 09-21-2005, 08:14 AM   #7
Peoples's Avatar
****.....i have a class d "1600 watt" amp (which seems to be pushing less then 800 watts, my opus, and the voltage regulator......i've seen people push much worse, why would my altenator suddenly take a dive?
PC Components:
My work log
Old 09-21-2005, 09:11 AM   #8
Peoples's Avatar
Ok. I disabled my fuse bear the battery for the amp, computer and voltage regulator. The lights went off. However I do notice my alternator making funny noise. Is it definatly a gonner?
PC Components:
My work log
Old 09-21-2005, 10:29 AM   #9
Banned
good buy stock honda alternator :-( we will miss you :'(
dont stress it mines gonna go out soon too
Old 09-21-2005, 12:00 PM   #10
MySQL Error
MatrixPC's Avatar
With Honda stock alternator?
You may have a problem there and it is already 5 or 6 years old (if it's not been changed.) Try the remove the POS terminal trick.
Old 09-21-2005, 02:22 PM   #11
http://www.v6performance.net/store/p...4a77322d9d71db
Old 09-21-2005, 03:28 PM   #12
Peoples's Avatar
ok, I bought a 200 watt alternator. I read that they recommend running a 4-guage wire for the main power wire for the alternator. Does anyone know where I can purchase a harness for an alternator with a 4 guage wire?.... dont want to ghetto rig this thing with some of my red 4 guage.
PC Components:
My work log
Old 09-21-2005, 03:48 PM   #13
mykolJay
not to hijack you're thread...how do you reset the ecu on a 6th gen accord (98-02)?
Thanks.
mykolJay
99 Accord coupe
http://www.geocities.com/accordpc
My Project Thread on mp3car.com
mykolJay is offline   Reply With Quote
Old 09-21-2005, 03:55 PM   #14
Peoples's Avatar
I believe fuse #13 (on the passanger side)...at least thats what I've read
http://www.v6performance.net/forums/...ad.php?t=22207
http://v6p.net/forums/showthread.php...69472#poststop
PC Components:
My work log
Old 09-21-2005, 05:14 PM   #15
yep did you get one from v6p peoples? and if so, what's your name on there?:P
2003 2004 2005 Honda Accord CarPC Adam2312 Newbie 161 02-09-2009 10:25 PM
VW Owners / Dimming lights TheSpatulaOfLuv Power Supplies 16 09-16-2005 08:48 AM
