Go Back   MP3Car.com > General > Off Topic
Old 11-12-2005, 10:41 AM   #1
sdashiki's Avatar
sdashiki is on a distinguished road
Something TERRIBLE about the air industry...
Just watched CNN, ill paraphrase:
Air traffic controllers (ATCs) might possibly finally get what they have been asking for since 1990. The ability to track aircraft on the ground at their airport, in real time. Just in the same way the radar screen etc that ATCs look at all day, just not at 1000-40000 feet, instead at 0 feet.
So basically youll have a screen that looks like a map of all the tarmac/runways/gates etc. With little blips for each "active", which I guess means either pulled away from a gate or turned "on" in some sense, aircraft. Each blip tells you the carrier/tail#/flight# etc of the plane. Without this, its up to each aircraft/pilot and the ATCs to make sure no one is taking off with someone landing, etc etc.
One would think that this kind of thing is in place already, but no, its big towers, glass windows and binoculars with maybe some computerization.
What struck me as so odd is that this is like common sense, especially when we have the ability to track the same info IN THE AIR, yet not 1/4 mile in front of us.
Just had to tell you something Im sure you assumed ATCs and pilots had access to. But they dont. CNN was remarking on the fact that a couple of airports are testing these kinds of systems, but nothing is approved and even when approved the NTSB has yet to say whether it will ever get federal funding for every airport.
LOL.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 11-12-2005, 10:55 AM   #2
kiltjim's Avatar
kiltjim is on a distinguished road
Air Industry?
What the hell does this have to do with the production and sale of air?
Scary nonetheless...
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
kiltjim is offline   Reply With Quote
Old 11-12-2005, 11:21 AM   #3
RPI Geek's Avatar
RPI Geek is on a distinguished road
When I took flight lessons one of the first things they taught me is that it is ALWAYS the ultimate responsibility of the PILOT to keep a watchful eye and avoid collisions. This might have changed when it came time to file for IFR flight but I never got that far.
"Ability to track" for what purpose, security? safety?
Security:
Even the in-air tracking can be disabled by simply flipping a switch on the transponder, and in certain circumstances it is legal to fly without a transponder at all. Heck, I've flown once or twice when I forgot to turn it on until I waws 10 miles from the airport. The radar might not even pick up the plane if it's far enough out of range / the right height / has a mountain in the way / there is no radar like in rural areas / a whole combination of other factors. What I'm getting at is that if a similar device is used, or even if it's the transponder itself, the pilot can just turn it off.
Safety:
IMHO no pilot should ever cross a runway without carefully checking for traffic, and at lots of airports there are cars, baggage handlers, maintenance and construction vehicles, flocks of birds, etc. I was going to blast this too, but now that I think about it I can see how safety could improve, but only marginally. I suppose that even if 1 life is saved it would justify the costs.
If you thought they had this then you'd probably be amazed with the minimum equipment list required for flying, it's pretty damn sparse. Then again, the last time I flew was before 9/11 so things may have changed since then, but I doubt it.
Old plans out the window because of an accident .
Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
Need: Time, HU integration, ideas for Lilli
RPI Geek is offline   Reply With Quote
Old 11-12-2005, 02:20 PM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
This is a case where a seemingly simple problem isn't. And when problems are complex, they cost big $$$. That is the case here.
Tracking the position and information of every aircraft on the surface of the airport is fundamentally different from doing it in the air because there are other things on the surface, including vehicles, buildings, and people. In the air, this is not the case.
On the ground, radar returns are affected by the weather such as rain and also by the fact that if you only use a single antenna, it is difficult to ascertain the exact position of the aircraft without some way to triangulate. Radars measure how long it takes for a signal sent to be returned. On the surface of an airport, this requires an extremely accurate system.
In the air, the minimum separation distance is 5 miles in most cases. The accuracy of the radar doesn't have to be nearly as high and in many cases, returns from several radars are pieced together to ascertain the position of the aircraft. However, ATC doesn't know PRECISELY where the aircraft is but they have a reasonable estimate and the separation standards are designed to accomodate any error.
Add on to this that you are talking about a government agency procuring a limited number of systems (perhaps 400 at the absolute outside, but more like 100 or less for the larger airports) and one that doesn't have a good track record for coming in on time, under budget, or even successfully completing their projects.
In addition, runway surface movement is accomplished by trained professionals who may only use their eyes but are nonetheless trained professionals. The system works and works well. Add to that budgetary pressures cause procurement to be drawn out over a period of years rather than outright cancellation of a project and you can begin to see why they don't have this.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 11-12-2005, 03:21 PM   #5
rushnrockt is on a distinguished road
It is 2 miles for most international airports and the main concern is not the "accuracy" since radars and gps systems are capable of figuring out the distance pretty darn well, but the fact that any distance closer than that, the turbulence of one airplane will mess with the next airplane. Radars have been around for a century, they are not so imprecise that you have to "guesstimate" the location of the airplane. Radar guided anti-aircraft artillery has been around for decades and that requires one hell of a good accuracy.
You sure that those trained professionals would not have something against a computerized system that will take their jobs away? Hmmm, might be another hurdle in implementation process over there
I have found you an argument; I am not obliged to find you an understanding.
rushnrockt is offline   Reply With Quote
Old 11-12-2005, 03:54 PM   #6
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
I can't be arsed reading this. is it about ground radar tracking of planes and vehicles around the airport? If it is then it has taken ages to do because it is so bloody hard to do accurately. There is no point in having such a system if it is not 99.99999% accurate or cars will get squashed by a 747!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 11-12-2005, 04:28 PM   #7
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Just give them nice big wing mirrors (I mean the wings are big enough for gods sake) and a nice CCD reversing camera, and there'll be no problems.
Enforcer is offline   Reply With Quote
Old 11-12-2005, 07:05 PM   #8
Bugbyte's Avatar
First, you are talking about what is called the "terminal" domain. You'll not that I said "in most cases". The terminal is a case where that separation standard can be reduced if visual separation is maintained by the pilots. In that case the wake turbulence can be a limiting factor and varies by aircraft size. 2 miles for some, more for others such as the 757.
Second, GPS has nothing to do with radar surveillance. Yes, pilots know where they are very accurately but that information is not relayed to the air traffic controller.
You are incorrect on this point. Radar is used to determine the range and bearing but is not used to guide the projectile. In addition, radar is not as accurate as you think.
An automated ground control system is so difficult to design, they don't need to worry.
Want to:
-Where is the iBug?
Old 11-12-2005, 07:47 PM   #9
I am aware of that, yet no one prohibits this simple device from being used.
Radars had an accuracy of 50m before WWII... they have since improved a bit And again, I don't see particular use for a radar in the airport when GPS or RFID tags would do.
Although admittedly its a very detailed task, it is not so difficult, considering how there are entire automated factories out there. People involved in wrestling with each other, meaning government (the one spending money), outside companies (the ones getting money) and the previously mentioned professionals (the ones standing to lose money) would be the most significant factors in slowing down the creation and adoption of such systems. If Walmart can do tracking, government backed designs better be able, or I am voting for Waltons in the next election.
Old 11-13-2005, 12:55 AM   #10
Bugbyte's Avatar
True, but we are discussing the ASDE-X ground radar tracking system and that does use radar. You are correct that the best solution is to have aircraft self-report their own positions and use that information for surveillance. This is known as ADS-B or Automated Dependent Surveillance (Broadcast) and would work not only on the ground but also in the air. This system is still experimental and would solve the problem but requires all vehicles/aircraft to be equipped to this standard. Since the system is already extremely safe (not foolproof, but very safe), the cost/benefit story isn't positive.
I believe you underestimate the challenge. Remember that air transportation has an unparalleled safety record and maintaining such a standard requires a system that works perfectly at all times and under all circumstances or it will be less safe than the current manual system.
Factories are controlled environments where repeatable processes can be refined and controlled. They do not have to work when snowplows have accidentally crossed an active runway, when pilots accidentally land on the wrong runway or taxiway, when a tire blows on landing and closes the active, when the taxiway is blocked by a pilot unfamiliar with the airport layout, when a pilot has a stuck microphone blocking communications with everyone on that frequency or any of a thousand other unexpected variables that require human judgement and problem solving skills.
One must also deal with differing levels of equippage of those aircraft, some of which may have full blown avionics and flight management systems in them, and others which may have non-working transponders.
Insurmountable problems? Maybe, maybe not. But devising an automated ground control system would almost certainly cost more than the benefit it would deliver and the safety certification of such a system would be monumental. It may be much cheaper to simply help controllers out by giving them better information about where the vehicles are on the surface.
BTW, in case you wonder why I'm all over this, I work at a federally funded research and development center that researches and analyzes the air traffic control system for the FAA.
Want to:
-Where is the iBug?
Old 11-13-2005, 01:32 AM   #11
84RegalRider's Avatar
84RegalRider is on a distinguished road
GPS-mouse, laptop, lil wifi connection... am i missing something to solve this problem?
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
84RegalRider is offline   Reply With Quote
Old 11-13-2005, 03:28 AM   #12
Bugbyte's Avatar
Right. Well the original thread is about how shocking it is that there is no ground radar tracking at airports and how that should be an easy thing to engineer.
Of course you can come up with a solution to this problem. I think what I am trying (and failing) to get across is the fact that these are operational systems and as such, have to be both highly reliable and be able to be relied upon for accuracy routinely. You simply can't afford to drop the Wifi connection at SFO in the fog and let a plane stray into the path of a landing aircraft.
And really, think about it. Would you trust a Windows box to fly a plane you were a passenger in? How about to drive a car you were a passenger in? Of course not. You'd need something far more robust and fault tolerant, which is why aircraft electronics have to survive lightning strikes. It's a completely different level of engineering.
Want to:
-Where is the iBug?
Old 11-13-2005, 04:04 AM   #13
roadhog's Avatar
roadhog is on a distinguished road
Back in the mists of time I remember aircraft landing by ALS with RF beacons on the runway approaches... Does this still happen? if so why can't the ATC keep an eye open on where they berth? ok it might be heathrow with 6 planes per min. but 10 ATC are on the job?
roadhog is offline   Reply With Quote
Old 11-13-2005, 07:21 AM   #14
lez
lez's Avatar
lez is on a distinguished road
I've a chaper idea, all aircraft have aerials / antennas dont they?
Now I've seen this work in carparks at walmart so it should be easier in a bigger space with more gaps/visibility etc between the planes.
You spike a coloured ping pong ball onto the top of each aircraft aerial.
Now they can see where have parked.
lez is offline   Reply With Quote
Old 11-13-2005, 08:55 AM   #15
MySQL Error
, i'll suggest that next time I am up at Airbus!
COOL carputer with AC? eduardovdr General Hardware Discussion 43 01-28-2006 07:54 PM
Anyone ever make an air vent? Subwoofer87 General Hardware Discussion 19 04-05-2005 03:48 AM
Air Traffic Control humor Chairboy Off Topic 25 03-22-2005 10:37 PM
Air Conditioning Deterioration Jamez_Warner Off Topic 3 04-27-2004 03:18 PM
fans LudeAtude General Hardware Discussion 22 04-23-2004 01:55 PM
