Go Back   MP3Car.com > General > Off Topic
Old 01-20-2006, 11:37 AM   #1
3onDubs's Avatar
3onDubs is on a distinguished road
Car almost caught fire yesterday...
I have my BMW interfaced with an I-BUS controller so that I could send steering wheel commands through my computer.....
I'm driving home from work and I realize that my steering wheel controls aren't working for my carputer. After messing around with the control panel, I realize that the computer isn't detecting it, which means that it was probably unplugged. So, I stop for gas and check out the connecter in the trunk....surely, its unplugged. I plug it back in real fast and jump back in my car.
After a few seconds smoke starts filling my car. It starts off with just the smell of burnt metal and rubber, and within a minute there is a thick cloud of smoke surrounding me. I roll down the windows and look in between my seat and the center console and I can see an orange flickering glow...FIRE! I pull over and pull the computer out from under my seat (thank god I didn't end up bolting it down) and I could see that the flame is on one of the prongs of the serial plug that connects to the computer from the i-bus controller.
I blow out the flame (which is only the size of a candle flame...nothing else got damaged), disconnect the serial cable, and slide the computer back in. I open my trunk and there is a similar burnt smell. I check the connector on the i-bus and the entire serial cable is fried. I check the pins on the cd changer harness, and it turns out that I connected the cable wrong....I was sending 12V through the ground lead everytime I pressed a steering wheel button.
It turns out that every button press was sending a spark through the serial cable and I remember pressing the buttons repeatedly in frustration while trying to get it to work....its good that nothing else happened, but just a warning to anybody who is using the i-bus.....make sure you connect the pins correctly...
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
3onDubs is offline   Reply With Quote
Old 01-20-2006, 12:03 PM   #2
sfay93's Avatar
sfay93 is on a distinguished road
NO! Make sure you fuse any and all power leads. This would not have happened if you had protected your equipment by using fuses.
ATVMS.com
sfay93 is offline   Reply With Quote
Old 01-20-2006, 12:23 PM   #3
sdashiki's Avatar
sdashiki is on a distinguished road
Wow power without fuses, man u were taking a risk.
(----) 0.0%
No more loot for the carpute.
Trying to fit my 20" iMac into the dash... RF 600.5 amp, two 10" JLW0, 8 Infinity Components
sdashiki is offline   Reply With Quote
Old 01-20-2006, 12:30 PM   #4
3onDubs's Avatar
I have fuses on all power lines comming out of my battery. What happened is the serial cable caught fire. There is a factory cd changer harness that plugs directly into BMW stock cd changers. This plug, plugs into a chip called the i-bus as well. On one end of the i-bus there are four prongs for the cd changer harness, and on the other end there is a serial connector for the serial cable. There is really no place to put a fuse if you think about the way things fit together. What happened, is I plugged the cd changer molex connector backwards....
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 01-20-2006, 12:57 PM   #5
Raw Wave
BoyNextDoor's Avatar
BoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud ofBoyNextDoor has much to be proud of
interesting... i thought BMW's are better than that... I took my car apart several times, and all the connections are like you can only connect them one way... That sux...
Anyways. Glad nothing else happened... Oh, and remember to buy a fire extinguisher for your car. I bought one fr home/office use ($20 @ homedepot) and always keep it with me... You never know what could happen. Or you may be able to help someone out...
BoyNextDoor is offline   Reply With Quote
Old 01-20-2006, 01:14 PM   #6
3onDubs's Avatar
Seriously, lucky for me it was just a candle sized flame that I was able to blow out....i can't imagine what would have happended if it was bigger. Luckily, nothing happened to my computer or regulator (which were both right there by the flame)...
...BMW parts are better than that, but the i-bus chip isn't made by bmw...I bought it online so that it could interface my car with my computer. It's actually my own stupid fault for not paying attention while plugging it in. I never knew that a serial cable could catch fire like that...
PostCount++
- SrCsTc's Bezel
- Alpine W200/H701
- ED Nine.2X
- OZ Matrix Elites
- ED Nine.1
- Idmax 12's
Old 01-21-2006, 08:58 AM   #7
mp3hombre's Avatar
mp3hombre
Huh? All molex connectors that I've seen (and i've seen a lot!) are "polarized". You can't connect them backwards.
Anyway, i'm happy you're OK dude.
mp3hombre is offline   Reply With Quote
Old 01-21-2006, 09:48 PM   #8
84RegalRider's Avatar
84RegalRider is on a distinguished road
u can put a fuse on any wire. Shoulda fused ur serial cable
haha (jk) kinda, might not be a bad idea for you
Core duo
1tb harddrive
256 ddr
8 lilliput
bu-353
still installing...
84RegalRider is offline   Reply With Quote
Old 01-22-2006, 10:17 PM   #9
HHdesign's Avatar
HHdesign is a jewel in the roughHHdesign is a jewel in the roughHHdesign is a jewel in the rough
I had the same thing happen to my jeep, but it was really weird, one of my power wires grounded out and my fuse didn't blow... Needless to say I am very lucky as one of my fuel lines had burn marks on the outside.
Jeep Grand Cherokee Laredo
Kenwood X790 x/ iP500 Ipod Interface
Elemental Designs 13Kv.2 D2
CDT ES-620 (omg yayay!!!1)
NINe.2X, NINe.2
HHdesign is offline   Reply With Quote
Old 01-25-2006, 08:00 PM   #10
mp3hombre's Avatar
mp3hombre
So, I guess now you know that you shouldn't run power lines close to fuel lines...
What's your dream car? Aaron Cake Off Topic 172 10-02-2007 08:34 AM
Employee Discounted Cars: Flatout BIG LIE! sdashiki Off Topic 33 10-31-2005 06:53 PM
Article: Big Brother in the car VanMan69 General MP3Car Discussion 3 08-08-2005 12:00 PM
Car as Daemon thecapitalizt Linux 1 08-01-2005 11:27 PM
New Bee.. thing i want to do using mac mini in my car kingquattro MacCar 7 07-02-2005 04:47 PM
