Go Back   MP3Car.com > General > Off Topic
Old 03-19-2006, 11:15 PM   #1
Cheekz185 will become famous soon enough
HTML Frames?
Anybody goowd with HTML?? I am trying to do my homework here, and I am almost dont but I cant seem to get this to work. Here is the question:
open yale2.htm:
Create a frameset containing tree trows of frames. The first frame should be 85 pixels high, the thrid frame should be 30 pixels high, and the middle frame should ocupy the remaining space. The first frame will contain the Web Site header, the second frame will contain informational documents, and the thrid frame will contain the Web Site footer. Note: That the second frame will either display the Web Pages stored in the home.htm, philosph.htm and lessons.htm files, or it will display the frame layots stored in staff2.htm and tours2.htm files.
I am just having a problem with the "note" part. Can someone take a look at my codind and help me out? Attached are all the documents necessary
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 03-19-2006, 11:16 PM   #2
Here is where i believe i mite be having the problem:
<title>The Yale Climbing School</title>
</head>
<frameset rows="85, *, 30" bordercolor="brown" frameboder="0" noresize="noresize">
<frame src="head2.htm" marginheight="0" scrolling="no" />
<frame src="home.htm" name="docs" marginheight="0" marginwidth="10" />
<frameset cols="100, *, 100" bordercolor="brown" frameboder="5" noresize="noresize">
<frame src="staflink.htm" marginheight="5" marginwidth="5" scrolling="no" />
<frame src="footer.htm" marginheight="5" marginwidth="5" scrolling="no" />
<frame src="tourlink.htm" marginheight="5" marginwidth="5" scrolling="no" />
</frameset>
On the 6th line of that code is where the "second" frame is
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-20-2006, 12:14 AM   #3
fromplanetbob's Avatar
fromplanetbob is on a distinguished road
open yale2.htm:
I think the note part means you have to open the the webpages home.htm, philosp.htm and leassons.htm in the second frame, I'd open them with a menu in the first frame, it's something like <script>parent.frame2.document = "home.htm";</script> or in a link it'd be something like <A HREF="home.htm" TARGET="frame2">Click Here</A>
I'd assume the second form would be better, Teachers hate it when you do stuff more advanced than the lessons (often, I've found because they don't have any real world knowledge of how this stuff works, they only know what is correct by the book.)
fromplanetbob is offline   Reply With Quote
Old 03-20-2006, 08:06 AM   #4
Where would i enter the link?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-20-2006, 08:44 AM   #5
Black_Sheep's Avatar
Black_Sheep is on a distinguished road
I'm wondering what browser and version you are using. I downloaded it and tried the links and couldn't find any problems with your code or logic. All the links worked in IE 6.
A reference that I use for html (asp, ado, xml, and sql) is www.w3schools.com
If you make something Idiot proof....
The world will make a better Idiot.
CarPC Progresss: Planning [x-------------------]
Black_Sheep is offline   Reply With Quote
Old 03-20-2006, 09:22 AM   #6
Yale2.htm is supposed to display tlist.htm on the left hand side of the page in a frame...
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-20-2006, 09:50 AM   #7
<frameset rows="85, *, 30" bordercolor="brown" frameborder="1" noresize="noresize">
This is inside the center row. It defines a two column frame, first col is 200px, the second is whatever is left. It defines the first frame as "tlist.htm"
<frameset cols="200, *" bordercolor="brown" frameborder="1" noresize="noresize">
<frame src="tlist.htm" name="menu" marginheight="0" marginwidth="10" />
</frameset>
In the file tlist.htm make sure you change your <a href="*" ></a> to <a href="*" target="docs"></a>
Also you have your body in tlist.htm defined as:
<body style="background-image: url(wall2.jpg); color: white; font-family: sans-serif; font-size: 0.8em; font-weight: bold" link="white" vlink="white" alink="white">
This is giving you white text with white hyperlinks on a white background color. As I can't see your background image you may want to change the background color to something else by using background-color:brown in your style element for the body.
<frameset cols="100, *, 100" bordercolor="brown" frameborder="5" noresize="noresize">
</frameset>
I also found that you misspelled frameborder and set it to "0", when I corrected the spelling all your borders disappeared. So I set the width to "1"
Are Lilliput 7" Screen Frames Available? If So, Where? jmciver LCD/Display 2 11-28-2005 05:34 AM
Activex in the html page sam81 Map Monkey 0 07-31-2005 07:26 AM
Allowing html tags in signatures BiohazrD Mp3car Forum Suggestions/Comments 16 10-06-2004 12:39 AM
dvd player drops too many frames streetknight General Hardware Discussion 9 01-22-2004 01:13 PM
HTML SkinnyBoy Off Topic 3 01-21-2002 06:47 PM
