The MP3car.com Store
Go Back   MP3Car.com > General > Off Topic
Thread Tools Display Modes
Old 07-21-2006, 01:19 PM   #1
Raw Wave
Tidder's CarPC Specs
Tidder's Avatar
Vehicle: 04 Pontiac Sunfire (The Racer is dead...)
My Photos: (0)
internet connection monitoring software?
I'm looking for some software that can monitor an internet connection (DSL) and create a log of how many times connectivity was dropped. Anybody know of such a beast?
Tidder is offline   Reply With Quote
Sponsored Links
Old 07-21-2006, 01:32 PM   #2
IntellaWorks's Avatar
Vehicle: 2005 Toyota Tacoma
My Photos: (0)
Windows XP ? Doesn't the event log show such a thing???
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 07-21-2006, 05:23 PM   #3
Raw Wave
Tidder's Avatar
My Photos: (0)
Beats me. What would it be logged as?
Old 07-21-2006, 05:47 PM   #4
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
If you're directly connected to the DSL, you can use the Windows event viewer.
If you're connecting through a router, it likely has a logging capability, which you could enable, as well.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 07-21-2006, 05:50 PM   #5
My Photos: (0)
I honestly couldn't tell you. I've seen the errors or warnings before. Why do you think you've got a client with bad DSL service?
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
Old 07-23-2006, 12:58 PM   #6
Raw Wave
Tidder's Avatar
My Photos: (0)
Well just the opposite. They're connecting to some inventory server in CA from here in NM using telnet thru a VPN connection. What'll happen is the VPN will drop connection, then reconnect pretty quickly. But, when that happens, their telnet session disconnects, and when they try to reconnect, they have to call the company in CA because their session is still open on the server, so they can't connect until it gets reset.
Now the company in CA thinks its a DSL issue, but I don't think so. They think my client's DSL is diconnecting every so often. But from what I can tell, it's rock solid. I just needed a program that would log it so I could prove to them it's not the connection.
I think those Actiontec DSL modems do have some kind of log thingy, I'll have to check. In the meantime, if you guys come across anything, let me know.
Thanks!
Old 07-23-2006, 05:17 PM   #7
My Photos: (0)
Do it the simple way.
start --> run --> cmd enter
ping 127.0.0.1 -t > c:\Pinglog.txt
it will run until you press ctrl break
Search for the textfile for connection problems.
Only problem is there is no time indication so you dont know what time it disconnected.
There are programs out there. I just dont remeber them.
Hopes this helps a bit
darkwingduck is offline   Reply With Quote
Old 07-24-2006, 07:40 PM   #8
Vehicle: 1974 Ford Escort
My Photos: (0)
Have had this issue with an DSL router before client would randomly get disconnected whilst using VPN and RDP switched routers and problem went away
Also took client a couple of months to tell me as it was randomly happening so did not immediately check router and spent time checkin elsewhere
Soltek Qbic P4 3.4G - 1GB RAM - Lilliput 8"
1974 Ford Mk1 Escort
esky is offline   Reply With Quote
Old 07-25-2006, 01:53 AM   #9
Raw Wave
Tidder's Avatar
My Photos: (0)
Interesting, I do have a different brand DSL modem/router I could try, thanks esky. I'll give that a shot.
Sponsored Links
vB code is On
Trackbacks are Off
Imaginative Uses Of Internet Connection wolfebaine Wireless Communications 35 07-16-2006 03:32 AM
Need wireless internet advice / help ! coffeejolts Wireless Communications 8 01-29-2006 05:35 PM
Automatic Internet Connection? chronot150 Wireless Communications 23 12-04-2005 11:31 AM
Any nav software updates over internet? pip GPS 4 11-05-2005 11:50 PM
dual wifi cards - for constant internet connection neon_eddy Software & Software Development 10 09-18-2005 12:08 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
