Go Back   MP3Car.com > General > Off Topic
Old 09-04-2006, 07:30 PM   #1
Slightly_Stoopi is on a distinguished road
iPod DOWN!!!!
So my iPod's HD has got to be shot, it's a 4th gen click wheel with the black and white screen. All I hear when I try to boot it is some clicking comming from inside, a sad iPod icon comes up and thats it. I've tried fully charging, reseting, and I can't get it to recognize on ANY computer (I've tried half a dozen so far.). Anyone know how to homebrew hack one of these things to make it work again. I could send it to apple, but for the price of the repair I could get a new iPod though my school.
-Mike
Slightly_Stoopi is offline   Reply With Quote
Old 09-04-2006, 09:07 PM   #2
DJiK's Avatar
DJiK will become famous soon enough
Yes. Smack the iPod upside the head...
If you think I'm joking, you really haven't much to lose. So listen up.
If you're scared to do so, just let it drop on its side 3" on the table or 2" on the floor.
What you're hearing is stuck platters in the HD. Gravity does wonders!
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 09-04-2006, 09:28 PM   #3
stealinfool's Avatar
stealinfool is on a distinguished road
I've had similiar issues. yes, a smack has been known to fix it, just like your old TV. Also, if you can open it up correctly (without marring anything) then you can disconnect the battery, since that's the only TRUE hard reset.
DON'T PANIC.
Previous install pics in 2k3 S10
Project CarPc V2
stealinfool is offline   Reply With Quote
Old 09-04-2006, 09:32 PM   #4
you gotta be kidding me....so just drop it on the table ehh....i take it i should just drop it on the backside then huh.
-Mike
Old 09-04-2006, 09:48 PM   #5
SoulCoughy's Avatar
SoulCoughy is an unknown quantity at this point
My 4th gen started doing this. I took it apart, disconnected the HD cable (and probably some other cables). I then put it back together and it started working again. It's worth a shot, and if you have a flat razor blade, it's really easy to open.
SoulCoughy is offline   Reply With Quote
Old 09-04-2006, 10:07 PM   #6
well if the smack doesn't work, then i'll open it up. I don't have a razor blade...but i've got a butterfly knife and a switch blade here that may work :P
-Mike
Old 09-04-2006, 11:22 PM   #7
DJiK's Avatar
No, I'm not kidding (though I was more skeptical than you when I first saw the "dead iPod smiley").
I suggest you hit it on its side, that way the head will skip the platter instead of hitting it.
Old 09-04-2006, 11:34 PM   #8
Raw Wave
Chris31 will become famous soon enough
-Mike
Never use those stuff unless you want it looking like its been chewed by a dog.
Anything that need opening up like a TV remote that uses those all round clip to hold the case together or something similiar...
Use an old credit card plastic, using the corner of the plastic then gently slide it around as you turn the card to use its side. This way you are using the full side of the card keeping the case clip popped up as you slide around.
I use this trick all the time, the soft plastic card never damage the case.
Chris31 is offline   Reply With Quote
Old 09-04-2006, 11:39 PM   #9
The top needs to come out first, because the docking port will get damaged if you try to pull the top off evenly.
DON'T PANIC.
Project CarPc V2
Old 09-04-2006, 11:42 PM   #10
xgc
xgc is an unknown quantity at this point
also use a guitar pick to open the ipod, works perfect.
xgc is offline   Reply With Quote
Old 09-05-2006, 12:18 AM   #11
HAHAHAHAHAHA holy **** it worked!!!!! Thanks a bunch guys. I'm still gonna see if my dad wants this one since i will rarely or never use it since i've got the carPC now. I wouldn't mind getting a shuffle or an older iPod mini.
-Mike
Old 09-05-2006, 12:31 AM   #12
DJiK's Avatar
Which route did you go?
Old 09-05-2006, 04:34 PM   #13
I'll let this lyric from Prodigy explain what i did....
take my picture, smack my ***** up!!!
Dropped it onto my desk while the platters were clicking, fixed it. I'm probably gonna give it to my dad since he can at least use it in his miata till I get around to making his carPC...lol he's jealous of mine now. Though with his I'm gonna go a little better than a VIA setup. Since he's gonna give me the car in like a year or two, I'm gonna go and turbo the little guy and I want to run all my tuning stuff on the carPC. Probably won't bother putting in a HU either, just run the speakers off of an amp instead.
-Mike
