Go Back   MP3Car.com > General > Off Topic
Old 09-10-2006, 05:44 AM   #1
iyam is on a distinguished road
Fuses - ATC vs AGU vs MAXI
I'm looking at different wiring kits and noticed that different fuse types are used. Is there any advantages to one kind versus another? Here are examples of what I have seen.
ATC fuse:
http://www.cardomain.com/item/ROCCP10PI
AGU fuse:
http://www.cardomain.com/item/STRPS08BI
Maxi fuse:
http://www.cardomain.com/item/KIC05PK8
Any comments appreciated!
iyam is offline   Reply With Quote
Old 09-10-2006, 08:05 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
I don't think there are any advantages to one type of fuses over another. It's a matter of look and fit for your application. My distro block uses maxi fuses (which are just larger blade-style fuses). They're big and easy to pull in and out. Other styles are a bit harder to get to in a hurry.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-11-2006, 05:21 AM   #3
Thanks DP! I figured it was more of a personal preference. Anything that's easier to get to and use sounds good to me.
Fuses weasle1uk Newbie 3 08-15-2006 10:49 PM
what size fuses should i use chitown_16 Car Audio 10 06-25-2006 09:14 PM
What size Fuses??? BrentMcGhee Car Audio 5 02-28-2006 04:37 AM
Too many fuses? CavityCr33p Power Supplies 12 07-19-2005 11:21 AM
melted fuses corsamel General Hardware Discussion 10 03-26-2005 04:37 PM
