Go Back   MP3Car.com > General > Off Topic
Old 10-29-2006, 10:17 PM   #1
Dragonknell911's Avatar
Driving a manual
So who here drives a stick? I've been driving one for a long time but i'm sorta wondering about a few things....
If you drive a stick, when you start to brake, do you take it out of gear first or do you start braking first?
Do you take it out of gear around corners? Or do you just slow down and keep it in gear?
REBUILDING!!
Dragonknell911 is offline   Reply With Quote
Old 10-29-2006, 10:58 PM   #2
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
I don't drive a manual daily (unfortunately), but when I get to drive one, I usually just slow down, go from gear to gear until I'm in 1st. Then when I'm stopped, I put it in Neutral.
I do not take it out of gear around corners....
Peace,
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline   Reply With Quote
Old 10-30-2006, 12:13 AM   #3
I see dead kittens
Quattro's Avatar
my daily driver is a manual.
It depends on why your braking. If your just slowing down then I leave it in gear. If i'm stopping then I take it out of gear while braking.
again it depends on the corner. my most of the time I will take it out and probably go down a gear
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 10-30-2006, 12:53 AM   #4
But if you guys are slowing down, but still moving, you downshift?
REBUILDING!!
Old 10-30-2006, 12:54 AM   #5
Made It Obvious
Rafster's Avatar
I do...
Post # 3000
Items for Sale
Old 10-30-2006, 12:56 AM   #6
Well I get ~40 mpg the way I drive, however this winter im noticing considerable wear on my clutch
REBUILDING!!
Old 10-30-2006, 12:59 AM   #7
DJiK's Avatar
I've been driving/owning only stick AWD cars for the past three years.
When you start to brake, do you take it out of gear first or do you start braking first?
Just downshift. I always advise for it. Downshift consecutively down until second gear, then coast/break below 10MPH in neutral
Lately I've been practicing heel-and-toe braking. Earlier I got very fond of double-clutching and rev-matching. (If you don't know what these terms mean, Google them -- you won't be disappointed.)
I never take the car out of gear, but there's a difference in which gear to take the corner, It depends on the speed, the corner radius, and the road grip.
If I want to speed out of a corner, I usually downshift to a lower gear right before the turn. The gear I choose is the one which gives me the least toque in my highest-toque-band. For example: If my car's toque peaks between 3,000 and 4,000 RMP, I choose a gear that would give me revs in the low 3,000's.
In contrast, if I just want to have a nice "Sunday drive," then I keep the car in the gear that won't drop below 1,500RPM at the apex of the corner.
For Sale: Carputer (CarPC) & RCA Y-Adapter
Newsflash: Take a look at my unsold stuff above, thanks!
Up Next: Make an OBD to Serial cable & Redo the "MMI buttons"
DJiK is offline   Reply With Quote
Old 10-30-2006, 01:05 AM   #8
Haha I double clutch all the time, I had no idea what that was called. Yeah, I cant stand even the slightest 'lurch' entering gears, it gets me everytime
REBUILDING!!
Old 10-30-2006, 01:17 AM   #9
Raw Wave
Rob Withey's Avatar
Am I the only one that is genuinely scared by this thread?
Never ever take it out of gear and coast at any speed above 2nd gear. If you need engine braking you don't have it. If you need to put your foot down and go quickly you can't do it. As my driving instructor always said, a car out of gear is a car out of control.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 10-30-2006, 01:51 AM   #10
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
I do, and have for 15 years... The past 6 have been with a '96 Cobra and now a '98 Cobra...
As others have said, depends on why you're starting to break. Just slowing down, No. Coming to a stop, it depends on how fast I need to stop.
Fast? yes once I've slowed the car down to the lower RPMs for first gear, then it's outta gear and come to a stop.
Slow & can take my time... downshifting, till I'm approaching the lower RPMs for first gear, then I take it out of gear and come to a stop.
Again, as others have said... depends on many factors for the turn, but in everyday, good weather, normal road driving... I slow down, downshifting to a suitable gear for the turn, and normally accelerate out of the turn.
/edit: And Rob... lol You're right... The only time it's good to have it outta gear is when you're rolling down the street with a great Magnaflow Magnapack Exhaust system (or similar) and give a few nice 'pats' on the gas to say hello to a passing muscle car.. .. or to scare the local rice staring your car down..
W3bMa5t3r is offline   Reply With Quote
Old 10-30-2006, 07:20 AM   #11
XC-C30's Avatar
no, you're certainly not the only one!
I ONLY take it out of gear when parked. when I have to slow down, or when braking, I just shift back till 2nd. When stopped completely, I put it back in 1st.
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 10-30-2006, 07:34 AM   #12
Will I guess you both have plently of reason to be worried, since i honestly spend about a 1/4 of my time driving, coasting out of gear. Seeing as I drive over 400 miles a week, thats alot of coasting..
Maybe I fail to see the severity of this, but I don't exactly see the trouble with coasting whenever I can.
REBUILDING!!
Old 10-30-2006, 07:38 AM   #13
XC-C30's Avatar
driving out of gear is the same as constantly holding down the clutch. It's a good way to end the engine's life early.
@dragonknell: It's not because you drive alot, you KNOW how to drive. I'm not saying you're wrong, but you're giving a reason as why you should know what's best.... "because you're driving 400miles a week".... that doesn't make sence
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 10-30-2006, 07:59 AM   #14
I wasn't justifying coasting by saying I do it alot, i'm simply saying that I do it alot.
I really do not know what you are saying,
and I can not find anything relavent online that disproves or proves what you are saying.
REBUILDING!!
Old 10-30-2006, 08:05 AM   #15
bugbyte are you gonna step in and make things clear or just make sure our little discussion doesn't turn into a fight ?? =))
btw: I can find nothing now that says there is anything harmful about drifting in neutral with a manual tranny. The only thing I have found many times is that people think it is unsafe, in the event that I need to accelerate quickly to evade something.
REBUILDING!!
Drunk Driving Speech Cheekz185 Off Topic 15 06-24-2008 02:40 PM
Driving in Italy - An American View Bugbyte Off Topic 34 11-14-2006 06:50 PM
FS: EQ, Speakers, and Driving Lights techy101 Classified Archive 0 06-25-2006 03:33 PM
Thinking about going manual.. Song0330 Off Topic 79 02-21-2006 03:34 PM
Manual Shifter for driving games PSUSuperSenior Off Topic 14 03-02-2005 05:54 PM
