The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization
Thread Tools Display Modes
Old 04-09-2007, 12:24 PM   #1
mdlesk's CarPC Specs
Vehicle: 2005/Ford/Mustang
My Photos: (0)
High CPU Load after Install
When I was bench testing the CarPc, the cpu load was around 40-50% but then I added a wifi adapter and installed in the car and now the cpu load stays between 98-100%. My memory is 73% free. I turned off some more of the services but that's when it dropped to 99%. It was running a consistent 100%. Any ideas?
mdlesk is offline   Reply With Quote
Sponsored Links
Old 04-09-2007, 12:26 PM   #2
Fusion Brain Creator
2k1Toaster's CarPC Specs
2k1Toaster's Avatar
Vehicle: 2001 Honda Civic EX Coupe
My Photos: (1)
Roadrunner being used? If so, then do you have the correct flash version for it (8 not 9)? Have you checked the "high cpu load with RR" thread?
If not roadrunner, then the frontend and list of apps running while this happens would be nice.
Old 04-09-2007, 12:32 PM   #3
My Photos: (0)
I actually read that first thing this morning and was considering giving it a try, even though I use a different skin. I use the Digital FX skin, will doing the forced downgrade really make a difference?
Old 04-09-2007, 12:42 PM   #4
2k1Toaster's Avatar
My Photos: (1)
forced downgrade of flash?
Yes it will.
The thing is flash 9 uses some new way of displaying flash files. Legacy files meaning not 9 when tried to be played on a 9 system, have to be emulated or "swished" I believe the flash term is. I am not sure on the term, but it basically is running your flash in an emulator.
So if you go to a native flash 8 system, and try to play flash 8 files all the way back to 4 I think, you are fine. You cant play files encoded in flash 9 at all. And flash 4 and lower files are emulated, but you have to search high and low to find anything in flash 4 or lower.
So basically yes it makes a difference. On epia boards, it can make the difference between running smoothly, and running choppily and freezing. On a system with a dedicated gpu, then it will just emulate it there, and it should be a negligable gain in performance, but it still will help.
Old 04-09-2007, 12:50 PM   #5
My Photos: (0)
Okay, thanks. It's worth a shot either way. I am working right now, but when I get home I will try it.
Old 04-09-2007, 12:52 PM   #6
2k1Toaster's Avatar
My Photos: (1)
work?!
Work is for suckers! Just ask our belgian friend IC-C30
j/k buddy.
Old 04-09-2007, 01:59 PM   #7
XC-C30's CarPC Specs
XC-C30's Avatar
Vehicle: 1992 citroën AX MKII
My Photos: (0)
Quote: Originally Posted by 2k1Toaster View Post
work?!
j/k buddy.
Are you sure you still want to visit Paris nick? be sure I don't track you down then
Xenia: pink princess
status:
In progress
STATUS:
'T SQiekenkot: No Car
hardware: 0%
software: 0%
audio: 0%
building: 0%
XC-C30 is offline   Reply With Quote
Old 04-09-2007, 02:22 PM   #8
2k1Toaster's Avatar
My Photos: (1)
And how will you find me? Talk dutch to the parisians?!
I can just ask them if they found a weird belgian wondering around mumbling under his breath about a badger, and go the other direction!
Old 04-09-2007, 02:41 PM   #9
XC-C30's Avatar
My Photos: (0)
did you know I like hunting? And I don't care if it is hunting-season or not
status:
In progress
STATUS:
hardware: 0%
software: 0%
audio: 0%
building: 0%
Old 04-09-2007, 04:37 PM   #10
My Photos: (0)
I just tried it and guess what, it worse. The CPU is now a constant 100%!!! It did go down to 99% for a brief second, but went right backup. I don't know what to do. I am running RoadRunner, Wifi, Bluetooth, phonecontrol.net, Iguidance with Pharos GPS-360, and the recommended version of Winamp. I downloaded the replacement OCX flash file and renamed it flash9b.ocx since my other file was named flash9b. *UPDATE* After a fresh reboot it is down quite a bit now so it must have worked. But it still needs some work done. I'm now around 90% using Digital FX Skin. It is the same with the original skin. My goal was to be able to play music videos, but right now that seems impossible. Does anyone have ideas on what I can do?
Sponsored Links
Old 04-09-2007, 04:42 PM   #11
2k1Toaster's Avatar
My Photos: (1)
I know bluetooth is a beast on epia boards for some random reason. Try without bluetooth, and see how it is.
Old 04-09-2007, 05:01 PM   #12
My Photos: (0)
Okay, I'll have to give that a shot, but are there any options as i really want to use phone control with my slvr, plus I don't want to take it out again if I don't have to.
Old 04-09-2007, 07:29 PM   #13
My Photos: (0)
I just did a little testing and when I closed Winamp CPU usage went down to 30%. I am using the recommended version...what should I do?
Old 04-09-2007, 07:34 PM   #14
2k1Toaster's Avatar
My Photos: (1)
recommended do you mean 2.95?
Old 04-09-2007, 08:04 PM   #15
My Photos: (0)
Yeah, I am using Winamp 2.95.
Sponsored Links
vB code is On
Trackbacks are Off
Why can't I install windows XP ? please help ? shinjetko Newbie 24 09-19-2006 02:02 PM
Jagputer Install and story log JagPuter Show off your project 19 08-02-2006 08:48 PM
Tinyxp vs nlite vs sensible install geeky_hawkes WinNT Based 5 06-15-2006 03:55 PM
How should i install this? jnusaira General MP3Car Discussion 8 08-13-2004 03:03 PM
High Bright Sun Light Readable LCDs PORTUGAL LCD/Display 18 06-23-2004 11:19 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
