Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization
Old 03-20-2006, 02:11 PM   #1
onboard CF to ide->CF adapter.....won't boot anymore
I have an old single board computer with an onboard CF slot. I had installed win98 on a CF card using the onboard slot, and discovered that the onboard CF was limiting the speed of the CF card
So, I bought an ide->CF adapter. I know the adapter works fine, because I was able to boot off the CF like I had, and read the CF card from my camera using the adapter.
When I plug the CF w/win98 on it into the adapter, I get an "invalid system disk" error when the computer tries to boot.
I've already set up all the software on the win98 install, so I don't really want to go and reinstall win98 onto the CF card using the adapter. Is there a way to get it to work without reinstalling?
edit: the actual error message is "DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER"
dyne is offline   Reply With Quote
Old 03-20-2006, 02:26 PM   #2
roadhog's Avatar
Check in the BIOS which disk (CF adaptor) is set as the system disk, or bootable disk. Is the new cf slot is being assigned a different drive letter?
roadhog is offline   Reply With Quote
Old 03-20-2006, 04:50 PM   #3
Im not sure whether or not the CF card is being assigned a different drive letter.
The only option that I can see being relevant is "Boot sequence." I've tried every option with that and get the same "invalid system disk" error when trying to boot
edit2: I get the same error message if there is no disk inserted
Old 03-21-2006, 08:04 AM   #4
SlashEMc2k's Avatar
check the boot up order and also make sure you haven`t got a floppy in the diskdrive.
SlashEMc2k is offline   Reply With Quote
Old 03-21-2006, 08:35 AM   #5
Of Ice and Men
LagunaICE's Avatar
BTW I wonder whether you had your CF card write protected.
LagunaICE is offline   Reply With Quote
Old 03-21-2006, 11:44 AM   #6
I've tried every possible boot up order, to no avail. There also isn't a floppy drive in the computer, so that's not it
what exactly do you mean? To limit the write cycles, I just turned of the page file. I doubt the amount of write cycles will destroy the card any time soon, so I figured I'd see how long this one lasted and just buy another one when it dies
Old 03-21-2006, 11:50 AM   #7
faichiu's Avatar
Make sure the bios see the CF card like a hard disk.
98 Honda civic
In-Dash LCD Monitor K-301
cappuccino EZ3
PIII-1.2GHZ
256MB PC133
40GB HD
Holux GR 213 Sirf Star III GPS
IguidanceV2
CNX-P1900 power supply
Sound Blaster Live USB
faichiu is offline   Reply With Quote
Old 03-21-2006, 03:37 PM   #8
There is an "IDE HDD auto detection" option on the BIOS, which reads out the same data for the CF card, whether it's using the adapter or onboard slot
From that I'm assuming that it sees the CF as a hard drive
Old 03-23-2007, 03:47 AM   #9
IDE to Compact Flash
IDE to Compact Flash :
These units allow users to replace traditional hard drives with standard Compact Flash cards.
There are some real nice bennefits to using compact flash in place of a regular hard drive.
These include:
- very low power consumption (less then 0.5W)
- Fast startup, no spin up time, or USB bottleneck
- high transfer rate
- phisically very durable
- compatibility with IDE drivers, nothing special needed
- they are completely silent
- The use commodity (cheap and plentiful) CF cards
Last edited by meddler; 06-22-2007 at 07:45 AM. Reason: removal of commercial link
matt518000 is offline   Reply With Quote
Old 02-15-2008, 01:26 AM   #10
re:CF to IDE
make sure your CF card work on the DMA mode , not PIO mode .
IDE to CF Adapter,SATA to CF
PCI Riser Card,IDE to SD/ZIF/SCSI/SlimCD-ROM
making data communicate easy
http://www.soarland.com/
easyadapter is offline   Reply With Quote
Old 02-29-2008, 08:06 AM   #11
yeesh, this thread is almost 2 years old. I got rid of the SBC long ago
Old 03-13-2008, 07:44 PM   #12
anyone willing to take me CF and load a booting XP on it. let me know how much. I have my own XP license.
LindyM is offline   Reply With Quote
Old 03-14-2008, 02:29 AM   #13
Raw Wave
Rob Withey's Avatar
They would need the same hardware as you. You can't install on one machine and expect it to boot on another.
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Argh! Two Problems: USB HD wont read on boot, only after, and CF prevents boot also.. wardemon666 General Hardware Discussion 10 04-17-2006 05:23 PM
IDE to USB adapter & Hibernation problem nkotch General Hardware Discussion 0 03-15-2006 04:55 PM
onboard CF slot reading slow (win98 + twinmos 140x card) dyne General Hardware Discussion 3 03-04-2006 10:19 PM
IDE adapter and cable orientation Musashi450 Newbie 3 01-04-2006 05:43 PM
boot from CF? etrik General Hardware Discussion 5 02-09-2002 01:08 PM
