The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization
Thread Tools Search this Thread Display Modes
Old 11-16-2006, 08:28 PM   #1
PhilMayfield's CarPC Specs
Vehicle: 2008 Mazdaspeed3 GT
My Photos: (1)
S3 but no stand-by option?
Okay, got kind of a weird problem, and couldnt find an aswer searching.
I have my system pretty much ready to go, but for some reason, when I enable S3 in my bios, the stand-by option goes away in Windows.
When I switch to S1 in bios, the stand-by options is there. Weird.
Short of trying all the options in S3 mode, Im confused.
Id really like S3 so the fans and crap would turn off, any ideas?
PhilMayfield is offline   Reply With Quote
Sponsored Links
Old 11-17-2006, 05:44 AM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
If the BIOS doesn't support standby in S3, there's nothing that can be done short of hacking the BIOS.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 11-17-2006, 06:38 AM   #3
MySQL Error
jcdillin's CarPC Specs
jcdillin's Avatar
Vehicle: 2002 Dodge Ram 1500 Quad Cab
My Photos: (3)
Did you have the machine to S1 or S3 when you installed windows? Because if you had it set to S1 then a reinstall might be in order. I've had some machines that if you didnt have it set to S3 during install then it will never work. The other thing is make sure your video drivers are installed properly because that can cause standby issues as well. Last but not least see if there is a bios update for your motherboard, it's possible the problem was fixed in a later revision.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 11-17-2006, 06:42 AM   #4
Of Ice and Men
LagunaICE's Avatar
Vehicle: Renault Laguna 2002
My Photos: (0)
do you have a correct VGA driver loaded? S3 will not be available with "standart VGA" driver
LagunaICE is offline   Reply With Quote
Old 11-17-2006, 07:17 AM   #5
DavC's CarPC Specs
Vehicle: Vauxhall Vectra
My Photos: (0)
DavC is offline   Reply With Quote
Old 11-17-2006, 10:13 AM   #6
My Photos: (1)
My bios obviously supports S3 because it gives the option of S1, S1+S3 (not sure what this is), and S3.
I may have to try the reinstall thing, just cause there isnt really anything on the system at this point and it wouldnt be tough to do.
My display drivers are installed, at least not a standard VGA driver. I have a Geforce2 PCI video card to get 800x480 res. So Id definately need the driver to input special resolutions.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
number of days of standby (S3) time. kbyrd Power Supplies 43 04-29-2006 01:24 AM
Ignore thread option? mox Suggestions/Comments 12 11-22-2005 05:33 AM
Should I chuck this board? Importance of S3 Suspend? GnatGoSplat Newbie 7 11-14-2005 03:58 PM
Xenarc and AV2 first option aguiu LCD/Display 2 05-31-2005 06:19 AM
OPUS 150 SFX Fan or XPC Fanless Casing Option lostreception Power Supplies 1 05-27-2005 03:39 PM
Sponsored Links
Ad Management by RedTyger
