Quote: Originally Posted by
Nerd2
I did it after much pains using a win98 bootdisk copied onto the hard drive, along with the i386 folder from winxp - then install. Much more complicated than this though and took a while
- oh and no floppy drive either.
With a floppy drive it's easy surely? you just copy your i386 folder onto the harddrive - load up a win boot disk. run "smartdrv.exe" (put it on the floppy or harddrive), then run winnt.exe in your i386 folder and you're done.
TinyXp version don't have winnt.exe because manual installation is removed...I understand wkm1 problem because it's also my problem with the same fujitsu subnotebook(No cdrom no Floppy)
We can easily install normal copy of WinXP,simply put into HD the whole contents of original XP CD or put ISO image on HD and the mount it through Demon tool...But for this subnotebook we need a tinyXP version that work with few RAM...Unfortunately in all TinyXp version manual installation(so setup.exe,winnt.exe etc etc)are removed,and we can't install it!!!
Hope someone can help me and wkm1,in how to add manual installation to TinyXp Version.
PS.I try also to make my own Tinyxp with nLite but the result is a version not fast then the original tinyXP by eXPerience.
Have a good Day,
Blest
