Since the forum to get the app, and the developer, are both german I thought id share the steps I used to get it working
Everything except for the maps you get from:
http://www.mp3car.com/vbulletin/newt...ewthread&f=113
You do have to sign up, and it is in german. Google translation tool can help you work out which fields you have to fill in for the registration. Once you have a registered and signed in you should be able to go to the above link.
From the first page grab:
DestiPLus v5.61 by jennico.exe
Language5.0.zip
Destinator PN.rar
The maps you can get from your Destinator 6 CD.
For the example I have installed everything in to c:\desti. Destiplus doesnt like spaces in the filename.. so...
1) Create a directory in C: called Desti
2) Extract Destinator PN.rar to C:\Desti
3) Extract Languages5.0.zip to c:\Desti
4) Delete the Berlin Map folder (unless you want it)
5) Copy the map folder to c:\desti
6) Install DestiPLus v5.6.1 to c:\desti. When the language screen appears I choose English as the language (click on the yellow dual arrow button) and chose USA as the country, then click on Ready
At this stage you should get a couple of prompts regarding license agreements, once you click on these Desiplus will go through its configuration routine that takes about 1 min. The application will appear to open and close a few times. Just wait till it stops. You should get a "Welcome and have fun with DestiPLUS" splash screen that you can click on.
Hopefully this will save someone some time
