Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Other Cool Front Ends
Old 11-04-2008, 04:46 AM   #16
Borte's Avatar
Borte is on a distinguished road
Quote: Originally Posted by serobb View Post
Hi Borte,
If you have read the first post than you have got the idea why I change the programming language ...
For the rest, yes I can send to you, but its completly new code, far away from the first one. I also used to google to get some ideas how to make thinks works for .Net. If you interest send me PM.
Rob
Hi again,
I have read the first post but I didnt understand if you had ended up on C# or .Net.
Is it so that you have changed like this: VB6->.Net-<C# and WPF? If so what was the reason for your change from .Net to C# with WPF? Isn't WPF a lot harder to run for a "older" computer?
Is your source for .Net or C#?
Cheers
Borte
Failure is not an option...
Borte is offline   Reply With Quote
Old 11-04-2008, 08:11 AM   #17
serobb's Avatar
serobb is an unknown quantity at this point
Hi Borte,
I have changed to C# with WPF stright away from VB6. There was not VB.Net between
I was thinking about, but I found examples used C# and XAML so I stick on that.
Why I really changed? Cause I wanted to make the UI more animated 3D, as well more nice.
For that WPF more heavy for an older computer... I never tired, could be...
But as everything has some advantage (e.g nice UI), also has disadvantage...
Rob
serobb is offline   Reply With Quote
Old 11-04-2008, 12:19 PM   #18
sniiki is an unknown quantity at this point
WPF is a lot better choice than traditional WinForms, as it uses relative dimensions and such (not resolution dependant when done right). Also, I'd say WPF UI runs a lot smoother than WinForm UI when talking about complex visual effects.
Planning to switch to WPF myself too.
sniiki is offline   Reply With Quote
Old 11-07-2008, 12:04 PM   #19
pierrotm777's Avatar
pierrotm777 will become famous soon enough
Downloadable ?
I Rob,
Where can i to download your completed frontend .
pierrotm777 is offline   Reply With Quote
Old 11-09-2008, 08:00 AM   #20
serobb's Avatar
Hi Pierrotm,
Quote: Originally Posted by pierrotm777 View Post
I Rob,
Sorry, there is no download release for iCar.Net yet. I planing to make it should be in two weeks, but only with limited function. Others are also in the way
Rob
Old 11-09-2008, 10:49 AM   #21
Why to limited
Hi Pierrotm,
Rob
Why to limited your job on this updload . It is a copyright problem ?
Old 11-10-2008, 09:41 PM   #22
serobb's Avatar
Hi Pierrotm,
No there is no any copyright and stuff...
Limited means there are some functions which are not fully developed, implemented yet, like phone, maps, clock, etc. That's why I called limited functions...
Otherwise of course no any limit, but only the stars on the sky!
Rob
Old 11-11-2008, 01:17 AM   #23
All star in the sky
Hi Pierrotm,
Rob
Ok Serobb,
I am impatient ..
Old 11-24-2008, 02:41 AM   #24
serobb's Avatar
Finally I can say there it is! The first release, still not very perfect and most of the functions are still missing, but already can use the videos part.
Some instrunctions:
I have only tested on Vista
Please update your Vista with Net 3.5 SP1 otherwise you got error. You can download from
here
Any problem pls feedback
Rob
Old 12-07-2008, 02:00 AM   #25
fantamos is an unknown quantity at this point
looks like a good start can't wait till you add more!
fantamos is offline   Reply With Quote
Old 12-08-2008, 06:25 AM   #26
Slayer84 is an unknown quantity at this point
Hello. First of all sorry for my bad english. I have problems using your software under Windows XP. I get an error from Microsoft .NET FRamework:
Code:
Method not found: Void System.Windows.Media.Animation.Storyboard.Begin().
I have installed .NET Framework 3.5 but I get the same error.
Thanks for your help.
Slayer84 is offline   Reply With Quote
Old 01-07-2009, 01:40 PM   #27
timwegman is an unknown quantity at this point
serobb: Have you had any progress so far. i have been watching the post and i like it so far i will change my skin as soon as you got a goob beta. i have xp tho so i hope it will work "or mabey i will upgrade my carpc" lol
timwegman is offline   Reply With Quote
Old 01-17-2009, 08:25 AM   #28
serobb's Avatar
Hi All,
Have been busy for last last couple of mth... iCar got a new skin and more functions.
Here is the latest beta, pls let me know your opinions!
Cheers
Rob
Old 01-17-2009, 09:16 AM   #29
Borte's Avatar
Hi serobb,
I'm still following your thread...
I tried your newest beta buy it crashes with a general error message, just saying that iCar has encountered a problem and needs to close.
I attached my log file contents here:
Code:
2009-01-17 15:13:19.562500 [Critical][1]: iCar is starting... 2009-01-17 15:13:19.562500 [Information][1]: Registering Message Broker 2009-01-17 15:13:19.562500 [Information][1]: Registering Plugin Manager 2009-01-17 15:13:19.562500 [Information][1]: Registering Settings Manager 2009-01-17 15:13:19.562500 [Information][1]: Registering String Manager 2009-01-17 15:13:19.578125 [Debug][1]: Deserialize(iCar.Localisation.RegionSettings,iCar.Localisation.RegionSettings.xml) 2009-01-17 15:13:19.578125 [Information][1]: Loading strings file: strings_en.xml 2009-01-17 15:13:19.812500 [Information][1]: Registering PlayerCollection Service 2009-01-17 15:13:19.812500 [Information][1]: Registering Theme Manager 2009-01-17 15:13:19.812500 [Warning][1]: ThemeManager: App.xaml was found, but we shouldn't use that one - App.xaml was prevented from loading 2009-01-17 15:13:20.093750 [Information][1]: Registering Navigation Service 2009-01-17 15:13:20.093750 [Information][1]: Registering Thumbnail Builder 2009-01-17 15:13:20.093750 [Debug][1]: MessageBroker: Registering object iCar.Thumbnails.ThumbnailBuilder 2009-01-17 15:13:20.109375 [Debug][1]: MessageBroker: Registering object iCar.Core 2009-01-17 15:13:20.109375 [Debug][1]: MessageBroker: sending iCar.Startup(iCar.Startup) message 2009-01-17 15:13:20.109375 [Information][1]: Plugin Manager Startup 2009-01-17 15:13:20.109375 [Debug][1]: MessageBroker: Registering object iCar.Plugins.PluginManager 2009-01-17 15:13:20.125000 [Information][1]: Loading Plugin files... 2009-01-17 15:13:20.125000 [Debug][1]: .Plugin: Plugins\Home\Home.plugin 2009-01-17 15:13:20.125000 [Debug][1]: .Plugin: Plugins\Menu\Settings.plugin 2009-01-17 15:13:20.125000 [Debug][1]: .Plugin: Plugins\MenuManager\MenuManager.plugin 2009-01-17 15:13:20.125000 [Debug][1]: .Plugin: Plugins\Music\Music.plugin 2009-01-17 15:13:20.125000 [Debug][1]: .Plugin: Plugins\MyWeather\MyWeather.plugin 2009-01-17 15:13:20.125000 [Debug][1]: .Plugin: Plugins\Radio\Radio.plugin 2009-01-17 15:13:20.125000 [Debug][1]: .Plugin: Plugins\Videos\Videos.plugin 2009-01-17 15:13:20.125000 [Information][1]: Autostart plugins 2009-01-17 15:13:20.140625 [Information][1]: Creating plugin instance: iCar.MenuManager.MenuManagerPlugin 2009-01-17 15:13:20.140625 [Information][1]: Loading Plugin: MenuManager.dll 2009-01-17 15:13:20.140625 [Information][1]: Assembly Version: 1.0.0.0 2009-01-17 15:13:20.140625 [Debug][1]: Initialising plugin: iCar.MenuManager.MenuManagerPlugin, id MenuManager 2009-01-17 15:13:20.140625 [Information][1]: Creating plugin instance: Home.HomePlugin 2009-01-17 15:13:20.140625 [Information][1]: Loading Plugin: Home.dll 2009-01-17 15:13:20.140625 [Information][1]: Assembly Version: 1.0.0.0 2009-01-17 15:13:20.140625 [Debug][1]: Initialising plugin: Home.HomePlugin, id 2009-01-17 15:13:20.140625 [Debug][1]: MessageBroker: sending iCar.StartupComplete(iCar.StartupComplete) message 2009-01-17 15:13:20.140625 [Information][1]: Navigation Startup 2009-01-17 15:13:20.218750 [Debug][1]: MessageBroker: sending iCar.Activated(iCar.Activated) message 2009-01-17 15:13:20.281250 [Information][1]: Creating plugin class instance: iCar.MenuManager.MenuItemBuilder 2009-01-17 15:13:20.359375 [Information][1]: Home Loaded Entered 2009-01-17 15:13:20.421875 [Debug][1]: MessageBroker: Registering object Home.HomePage 2009-01-17 15:13:20.437500 [Debug][1]: Deserialize(MyWeather.WeatherSettings,MyWeather.WeatherSettings.xml) 2009-01-17 15:13:20.609375 [Debug][1]: Deserialize(Home.HomeSettings,Home.HomeSettings.xml)
- Cheers Borte
Old 01-20-2009, 03:36 AM   #30
tacobandit is an unknown quantity at this point
can you change the button colors at all? Not digging the purple, maybe keep them all universal the same color?
tacobandit is offline   Reply With Quote
Tags
front ends, icar.net
Q's about making Plugins work with Front End software strifepeddler Newbie 0 07-16-2008 12:07 AM
what front end do you use? emdzey01 Software & Software Development 30 02-24-2006 08:07 AM
100% Plugin based Front End custardbomb Software & Software Development 19 10-07-2005 01:17 AM
Searching for the right Front End ninjatill Newbie 9 09-10-2005 03:47 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
