Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Other Cool Front Ends
Old 08-26-2004, 05:51 PM   #151
FreeDrive Creator
CdRsKuLL's Avatar
CdRsKuLL will become famous soon enough
When you first install it it asks you.. so I remember reading.. This all sounds very good, but way over my head. Trying to think what can I do to help.. There's alway the file sharing hub thats running.. ;-) Also I liked the way in frodo you could select 2 different skins a day and a night, not just a gamma adjust.. anyway I will keep watching to see if I can lend a hand in anyway.
CdR
www.cellsecurity.co.uk
CdRsKuLL is offline   Reply With Quote
Old 08-26-2004, 08:28 PM   #152
VENDOR - SpatialMinds
millec's Avatar
millec
CdR
The first time you run it asks you where the skin is, but where does it store this value? I want to change it now that I have selected a permanent directory but can't figure out for the life of me where it is kept.
millec is offline   Reply With Quote
Old 08-26-2004, 09:18 PM   #153
noodles's Avatar
noodles is on a distinguished road
I think HU deserves a new forum/section.
noodles is offline   Reply With Quote
Old 08-27-2004, 03:07 AM   #154
FreeDrive Creator
CdRsKuLL's Avatar
I also agree with a prev post about a system status page.. with temps of motherboard fan speeds, space on harddrives.. everything you see really when you do a /stat on irc if you know what I mean. This would be a greate idea. Also one of the main pains with mediacar when doing skins was there are 4 to do for each menu. If its possible to cut these down to just off and on, this would save loads of time for skinners.. ok you would lose your hover action, but if you are using a touchscreen this wouldnt really matter.
Old 08-27-2004, 08:15 AM   #155
more mods's Avatar
more mods
I like yhe four states, true the hover doent really do anything for touch, but not evryone uses touch screen. I vote leave it like it is!
more mods is offline   Reply With Quote
Old 08-27-2004, 09:04 PM   #156
NoPistonPC's Avatar
NoPistonPC is on a distinguished road
Hey guys. Sorry, I've been away from the forums for a while, but I will address everyone's comments soon.
In the meantime, I've had some time this week (for the first time in almost a month) to work on headunit. Here is the latest Windows version (Linux version will be ready later today or tomorrow):
headunit-0.2.exe
Comments/bug reports appreciated. Note: I've only worked on the audio portion in this release. Next, I will do Video.
Few things still missing from audio:
1. Reading ID3 tags. (first on my TODO list)
2. Visualizations
3. Equalizer
I will do all of these before moving on to the Video.
1994 RX-7, EPIA P4-ITX w/ Celeron 2.4 Ghz, Arise PSU, Xenarc 700TSV (new model)
NoPistonPC is offline   Reply With Quote
Old 08-27-2004, 09:11 PM   #157
NoPistonPC's Avatar
There is a new configuration dialog (thanks to knobby for getting started on this) that lets you change settings at any time. You can get to it from the main program by clicking on the "Appearance" button. Here you can re-sync the database, change your paths, change which file extensions are stored in the database, and choose which skin you want to use. Skins go in their own folder under the skins directory.
millec, the volume and other state information (current song, etc...) are now saved and restored properly. Also, all of your configuration problems should be addressed by this new config dialog.
cdrskull, that's a good suggestion, and it will be VERY easy to change the skinning code so that if the ON or DOWN files are missing, it will use the OFF file.
Old 08-27-2004, 09:29 PM   #158
NoPistonPC's Avatar
Quote: Originally Posted by aultl
Hey guys, I just got my latest copy of Linux Journal and guess what? There is in article on how to write a XMPCR frontend for Linux, do not know if this is something you guys are planning to add but here is the link any way.
Linux Journal: http://www.linuxjournal.com/article.php?sid=7487
OpenXM : http://www.beerboys.com/OpenXM/
Great! Thanks for the link. Now, I just need to buy an XMPCR.
Quote: Originally Posted by millec
What screen resolution are the skins designed to work with? I have a xenarc that I am running at 800x600 and it gets clipped on the right hand side and doesn't use the bottom 20% of the screen.
I am guessing 640x480? Can anyone point me to 800x600 skins or info on how to create one?
Thanks!
--Craig
The current size is hardwired to 800x480, but I will add the width and height as an option in the Configuration dialog so you can use any sized skin. Thanks for reminding me.
Old 08-27-2004, 09:46 PM   #159
NoPistonPC's Avatar
Does anyone have info on how to get access to this information on windows and/or linux?
Old 08-27-2004, 11:36 PM   #160
Hexerei is on a distinguished road
Won't df -h work for the hard drive space information? I'm not sure how to get fan information as I havn't bothered with that in linux yet. Maybe use some stuff from the uptime command?
Hexerei is offline   Reply With Quote
Old 08-28-2004, 12:00 AM   #161
millec's Avatar
millec
I was able to use a mediacar skin 800x600 that was designed to "stretch". It worked perfectly.
Old 08-28-2004, 12:04 AM   #162
millec's Avatar
millec
Thanks. I am running gentoo linux though. :-) I can be patient though.
Thanks,
--Craig
Old 08-28-2004, 12:07 AM   #163
millec's Avatar
millec
Some of it is under /proc, the rest is available via the lm_sensors package. http://freshmeat.net/projects/lm_sensors/
--Craig
Old 08-28-2004, 04:52 PM   #164
NoPistonPC's Avatar
Thanks,
--Craig
I run gentoo too, as well, also.
Anyway, the linux version is ready. You can grab the latest sources from CVS. Make sure you do a "cvs update -d" since the skins directory structure has changed. In fact, you may just want to delete everything and get the whole tree again...
Old 08-28-2004, 05:06 PM   #165
NoPistonPC's Avatar
I implemented the change into headunit so that if either the on or down files are missing, it uses the off file. But, I just realized that I didn't even need to do that. If you don't want to make 4 different image files, just make the off and the empty ones and specify the off image for down and on in your skin file. For example, in Audio_Player.skin, change the third line from:
audio_player_empty.jpg,audio_player_off.jpg,audio_ player_on.jpg,audio_player_dow
to:
audio_player_empty.jpg,audio_player_off.jpg,audio_ player_off.jpg,audio_player_off.jpg
This should work with the original MediaCar program too.
CarPC sound through car speakers without a headunit?, how? DSM97RS Car Audio 40 07-03-2006 06:38 AM
More Fuel to the Fire (New Frontend Software Screenshots) qjones Other Cool Front Ends 82 10-20-2005 03:38 PM
Powered by vBulletin® Version 3.8.2
Content Relevant URLs by vBSEO 3.3.0
